If your device won't turn on , you can access or replace the battery by using this guide. Also , make sure you have clean open place to work with. Make sure you have all the tools including the glue, which holds the battery to the panel.
Unscrew four Phillips #0 screws from the back panel.
Unscrew two Phillips #0 screws from the back panel.
Use a plastic opening tool to pop the right side of the panel.
Remove the tape.
Unplug the cable for the speaker.
Place the back panel gently on the table.
Remove the battery by using the IFIXIT plastic tool.
