The back cover of the device keeps all the components safe from damage and must be removed for any component to be replaced in the device. The back cover is held on by screws and is very easy to remove.
Remove the six 5mm Phillips #00 screws from the back of device.
Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
Use a spudger to disconnect the speaker connection from the motherboard.
