This guide walks through the process of replacing the internal speaker of a Magellan RoadMate 2120T-LM. The process is very simple and will only take about 15 minutes to complete.
Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
Pry up on back panel with black spudger
Disconnect battery and speaker cables from the motherboard at indicated places.
Use a spudger to remove the battery from the back panel.
Locate the internal speaker just above the battery
Remove the two 3 mm Phillips #1 screws.
