Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement
  1. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement, Strum Bar: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a size J1 head screwdriver, remove the six black 5 mm screws (circled in red) from the back of the strum button component.
  5. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the circuit boards from above and below the strum component.
    • Unplug the circuit boards connected to the strum component from the main circuit board.
    • You should now be able to pull out the strum bar.
Catherine Lintner
crwdns2935283:009/21/16crwdne2935283:0
581 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 1-1, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S1G1
Where can I fand a replacement part?
Logan Sturdivant - crwdns2934203:0crwdne2934203:0
The Strumfix Plus 4 from ByteArts is what I used for mine.
Ted Lawson -
crwdns2942667:0crwdne2942667:0 4,632
