Please remember that these controllers are not designed to be repaired so do not be surprised if you need to be rough with it or something was not initially installed correctly. Also, the same kind of screw was used throughout the controller.
Remove the six 7 mm Phillips screws from the rear cover.
Remove the two 7 mm screws on the closest circuit board.
Grip the sides of the motor you wish to replace and lift up.
Use a soldering iron to de-solder both vibration motor wires from the motherboard.
If needed, repeat the last two steps for the other vibration motors.
