Macintosh PowerBook 165c Trackball Replacement
  1. Macintosh PowerBook 165c Trackball Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Trackball Replacement, Input/Output Door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Trackball Replacement, Lower Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Trackball Replacement, Trackball: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Macintosh PowerBook 165c Trackball Replacement, Trackball: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
    • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
    • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
  11. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
  12. Macintosh PowerBook 165c Trackball Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all four components of the trackball assembly by lifting upward.
    • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
John
crwdns2935283:010/12/11crwdne2935283:0
88 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-3, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-3, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G3
crwdns2942667:0crwdne2942667:0 1,455
