Macintosh PowerBook 165c Display Replacement
  1. Macintosh PowerBook 165c Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orientate the computer right side up and open the display case to reveal the display.
    • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
  2. Macintosh PowerBook 165c Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
    • Twist counterclockwise to remove the screw.
    • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
  3. Macintosh PowerBook 165c Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
    • The display cover should release from top.
    • Remove the display case.
  4. Macintosh PowerBook 165c Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
    • Remove the black connector from the circuit board by pulling it away from its adapter.
  5. Macintosh PowerBook 165c Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
    • Caution: The display is no longer supported and must be handled with care.
  6. Macintosh PowerBook 165c Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully tilt the display downwards and rest it on the keyboard.
  7. Macintosh PowerBook 165c Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Macintosh PowerBook 165c Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Macintosh PowerBook 165c Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the orange ribbon cable on the back of the display.
    • Open the white tab fastener by pulling it outward.
    • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
    • The display is now free.
Jason
crwdns2935283:010/12/11crwdne2935283:0
89 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-3, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-3, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G3
crwdns2942667:0crwdne2942667:0 2,549
