crwdns2937539:0crwdnd2937539:0crwdne2937539:0
This guide will show how to open up the PowerBook so that you may access the hard drive, and then show how to remove the hard drive.
Turn the device upside down and then locate the battery latch near the front of the device.
Slide the latch to the left to release the battery.
Continue holding the latch then gently pull the battery out of the device.
Locate the CD-ROM Drive latch.
Slide the latch to the right to release the CD ROM drive.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Press firmly on each end of the speaker cover and slide it to the left.
Gently lift the speaker cover to remove it.
Lift the keyboard up from the back using a spudger(wedge side).
Gently lift the keyboard until only the ribbon cable remains attached.
Tilt the keyboard away from the screen.
Locate the six screws that secure the heatsink.
Remove the six screws from the heatsink using the Philips #1 screwdriver.
Lift the heatsink from the side closest to the laptop screen.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Locate and identify the two screws that attach the hard drive to the computer.
Remove the screws with a Phillips #0 screwdriver.
Once the screws are removed, lift up the end of the hard drive using your finger tips.
Fully lift the hard drive vertically against the side of the computer.
Push a finger down onto the plastic strap.
Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
crwdns2935229:011crwdne2935229:0
crwdns2917034:0crwdne2917034:0
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
