Macbook Pro 14" Early 2023 Trackpad Without Cable Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Unfasten the trackpad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Unfasten the trackpad: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the ten 5.7 mm screws securing the trackpad assembly:
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  2. Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Remove the trackpad: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Remove the trackpad: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Remove the trackpad: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the screen open slightly, but keep the MacBook upside-down. The trackpad should separate and lay flat on the display.
    • As you remove the trackpad, be very careful not to lose the six small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  3. Macbook Pro 14" Early 2023 Trackpad Without Cable Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the trackpad.
    • During reassembly, make sure that each of the nine washers are present before you install the trackpad.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
173.473 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.617crwdne2935297:0
crwdns2942667:0crwdne2942667:0 42
