This guide is an internal private guide used as a prereq.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
Use a spudger to pry the fan connector straight up and out of its socket on the logic board.
Remove the following three screws securing the fan to the upper case:
One 7.1 mm Phillips screw.
Two 5 mm Phillips screws.
Lift the fan out of the upper case.
Carefully pry the delicate rear speaker connector up off the logic board. These small L/R speaker connectors are quite easily broken.
Use the flat end of a spudger to pry the optical drive connector up off the logic board.
Use a spudger to pry the right speaker connector and sleep LED connector up off the logic board.
Use the flat end of a spudger to pry the trackpad ribbon cable connector up off the logic board.
Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable.
Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Use a spudger to pry the left speaker connector and microphone connector up off the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Gently pull the display data cable connector away from its socket on the logic board.
Remove the six 4.1 to 4.4 mm T6 Torx screws securing the logic board to the upper case.
Remove the two 4.1 to 4.5 mm T6 Torx screws securing the MagSafe board to the upper case.
On some models, these screws may be T7. Be careful not to strip away the head with a smaller bit.
Lift the side of the logic board opposite the ports out of the upper case.
Rotate the logic board away from the upper case until the ports clear the lip molded in the upper case.
Pull the logic board and MagSafe board away from the edge of the upper case as one piece.
