crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
Grab the white plastic tab and pull the battery up and out of the Unibody.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using both hands, lift and remove the lower case off the upper case.
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
Lift the mid wall out of the upper case.
Remove the two 5 mm Phillips screws securing the keyboard flex bracket to the upper case.
Lift the keyboard flex bracket out of the upper case.
Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
Remove the six 1.4 mm Y0 Tri-point screws securing the trackpad to the upper case.
Carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
De-route the trackpad cable through its slot cut into the upper case.
Pull the trackpad away from the outer edge of the upper case.
Remove the old trackpad and set it aside.
Carefully insert the cable from your new trackpad through its slot cut into the upper case.
Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
Pull the trackpad cable as you seat the trackpad into its void in the upper case.
Insert a 1.4 mm Tri-point screw into each of the outer holes drilled into the trackpad (two screws total).
While continually trying to click your trackpad, gently tighten the Tri-point set screw until the clicks return to their factory "feel".
Next, flip your upper case over so the keyboard side is facing up.
Align the trackpad so it is centered in its hole cut into the upper case.
Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
If its alignment looks good, install the rest of the Tri-point screws along the inner edge of the trackpad.
Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
crwdns2935229:059crwdne2935229:0
crwdns2944067:012crwdne2944067:0
The one thing I would be interested in: Where can I get the screwdriver this person is using in step 15? By this I am not referring to the low quality tools that are advertised alongside the tutorial.
--> can answer my own question. This is it: crwdns2937315:0IF145-072crwdne2937315:0
Is there a key to getting the front edge of the trackpad (side away from the keyboard) to sit up flush with the body? The trackpad is slightly recessed at the front edge of the unibody, but nice and flush near the keyboard. Any suggestions are appreciated.
Before going to the trouble and expense of removing the trackpad make sure you don't just have a problem with the battery. My trackpad was giving me fits by not responding or needing excessive pressure, etc. The only problem was that the battery was swollen and putting pressure up on the trackpad. Replaced the battery and the problem was solved.
I agree with Rich M - check the battery first! Swollen battery will impede the trackpad.
awesome instructions, thank you!
