crwdns2937539:0crwdnd2937539:0crwdne2937539:0
Use this guide to install a new hard drive in your MacBook Pro 17" Unibody for more storage space.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
Remove the lower case.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the hard drive bracket from the upper case.
Use the hard drive's pull tab to lift it out of the upper case.
Pull the hard drive connector away from the body of the hard drive.
Remove the hard drive from your MacBook Pro.
Remove the four T6 Torx screws around the outer edge of the hard drive.
crwdns2935229:0240crwdne2935229:0
crwdns2944067:011crwdne2944067:0
Very easy to follow. Replacing the HDD on these unibodies is super easy. Thanks for the guide.
Very easy, excepted for finding the right screw for Step 8. I replaced original HDD with a Samsung 840 EVO 500GB. Fine!
Exceptional instructions. If you're struggling to restore from a backup... connect your backup drive via cable, start your macbook, choose disk utilities, choose the new hard drive from the list on the left, if first aide options (repair/verify) are not available, erase and name the new drive, and then you should be able to restore from backup. :)
Thank goodness you posted this. I thought I messed up installation because there was no new HD when I turned on the laptop. I couldn't figure out how to restore. Then I saw this and tried it and it's restoring now. Thank you!!
Very easy, Thank you for this tremendous guide. Works perfectly and I directly connected my old HDD to USB and restore all my information using the Migration Assistant app. Fine!
