MacBook Pro 17" Unibody 2.2GHz early 2011 Duo
Vibrating noise from new MacBook Pro ?
Rattling fan ? Overheating ?
Give this a try !
I am using Husky screwdrivers HD 74501 U & HD 74502 Y
Turn your MBP upside down
Remove the screws from the back cover
Carefully open the back cover.
Remove the dust . I am using a vacuum cleaner here with a brush.
Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
Keep your Apple warranty and disconnect the battery.
Disconnect the fan from the mainboard.
Remove the 3 screws that fron the fan fixture.
Clean the dust with a very soft toilet paper.
This is what I´ve found inside one fan !
crwdns2935229:012crwdne2935229:0
crwdns2944067:06crwdne2944067:0
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
Thanks a lot s
Sanzi Gao - you are welcome!
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Try replacing the thermal paste, did that and my mbp mid 2010 works perfectly! Dosent even have to be expensive paste, I just used some chinesse one and it worked perfectly!
I now see about 78-82C of temperature with the fans making a small amount of noise. Before I saw from 90-98C and the fans were at 100% almost constantly.
Hope this helps!
