使用本指南来更换MacBook Pro电池。 更换电池需要三点螺丝刀。
拆下以下十个将背板固定在上壳上的螺丝:
三颗13.5mm十字螺丝。
七颗3mm十字螺丝。
将手指s塞入入下壳体和通风口之间,向上提起将夹紧下壳体的夹子离开上壳体上。
移走后壳。
使用塑料打开工具或者其他软小的带尖端的工具来小心地从右扬声器/低音扬声器外壳上揭起 警告:不要拆卸电池的贴纸。
从右扬声器/低音扬声器外壳上撕开贴纸。
抓住电池上的拉手,将电池从顶壳上移走。
充电至100%,然后继续充电至少2小时。接下来,拔下并正常使用以排空电池。当你看到低电量警告时,请保存你的工作,并保持笔记本电脑一直打开,直到它因电池电量不足而进入睡眠状态。等待至少5个小时,然后不间断地将笔记本电脑充电至100%。
如果你在安装新电池后发现任何异常行为或问题,则可能需要重置 MacBook的SMC。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
crwdns2935229:0205crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2944067:033crwdne2944067:0
There is a little rubber post under the battery, black with an orange inside guide. Where is that from?
Maybe good to know: as this type of MacBook Pro is already ageing, mine showed some bulging in the battery. As I don't use my MacBook Pro anymore as a real laptop, for me, it doesn't matter anymore to replace the battery. But for safety reasons, I removed the bulging battery, and the MacBook Pro is still running fine!
Hello, i've tryed to do it but without the battry my macbook didn't turned on... do you have any tip? Did you have to configure anything inside? My mac is a Macbook pro 17'' 6,1 mid 2010
@kirapereira, it should work. I took my bulging battery out and made no configuration changes. Just make sure you keep the MBP plugged into a working electrical outlet at all times and keep it plugged in while you are using it. If the magsafe connector gets dislodged for any reason the computer will shutdown immediately, no warnings or questions asked.
I just changed my A1297 model Late 2011 MacBook Pro 17" battery using a NewerTech battery kit (includes the two tools you need) that I sourced off OWC (OtherWorldComputing aka MacSales website) and using their installation video (while checking it against install guides on EverythingMac and the iFixit websites) The replacement went without a hitch and the battery is charging now The only thing I had to do was reset the clock after boot up I will report problems here, if any But if not, then Finito!
