MacBook Pro 16" 2021 Speaker Assembly Replacement
  1. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.1 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unclip the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unclip the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the rear cover's right clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the rear cover's right clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the rear cover's right clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the rear cover's left clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the rear cover's left clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the rear cover's left clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
    Terrifying, don't be afraid, give it a good pull, the description above is exactly right.
    Scott - crwdns2934203:0crwdne2934203:0
  5. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  6. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  7. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector on the logic board.
    This photograph does not match my 2021 Macbook Pro. Fortunately the differences do not impact the removal operation.⏎
    There is a different arrangement and number and type of chips to the left of the image.
    One square grey thing nad five rectangular black things ...
    Mine does not have the rows of test points above the track pad cable.
    Simon Anthony - crwdns2934203:0crwdne2934203:0
  8. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the trackpad cable bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the trackpad cable bracket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the trackpad cable bracket: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the trackpad cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the trackpad cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    There is a different arrangement and number and type of chips to the top/left of the red circle.
    Mine does not have the rows of test points to the left of the track pad cable.
  13. MacBook Pro 16" 2021 Speaker Assembly Replacement, Reposition the trackpad cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Reposition the trackpad cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery board: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  16. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
    This is SO small - I used a very fine guitar pick to get it to release, none of my tools were small enough.
  17. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the data cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the data cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
    There is a different arrangement and number and type of chips to the left of the tweezers.
  18. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the battery connector: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery power connector.
  19. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
    is it possible to buy/replace this battery power connector? I broke mine on the logic board side and they are impossible to find. Ofc apple want $900 because the laptop is "modified" after replacing the keyboard :|
    Thenon - crwdns2934203:0crwdne2934203:0
    The previous image did not match my Macbook Pro, this one does.
    Two square grey things, three rectangular smaller black things. :-)
  20. crwdns2944590:020crwdnd2944590:054crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the antenna bar's connector bracket: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the antenna bar's connector bracket: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  21. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the antenna bar: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the antenna bar: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the display cable covers: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the display cable covers: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the four 2.1 mm screws securing the display cable covers.
  24. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the display cable covers: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the display cable covers: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the two display cable covers from the logic board.
  25. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the display cables: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the display cables: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the display cables: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the two right-most display cable press connectors secured to the logic board.
  26. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous disconnection process for the remaining press connector.
  27. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the microphone cable connector.
  28. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
  29. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the microphone cable by sliding it out from its socket on the logic board.
  30. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the right-side cable covers: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the right-side cable covers: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the 11 screws securing the right cable covers to the frame:
    • Nine 2.1 mm screws
    • One 2 mm screw
    • One 3.5 mm screw
  31. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the right cable covers: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the right cable covers: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the five right cable covers.
  32. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the right speaker: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the right speaker: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the right speaker's press connector.
  33. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the headphone jack: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the headphone jack: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the headphone jack's press connector.
  34. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the right USB-C ports: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the right USB-C ports: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the right USB-C ports: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the right USB-C ports' two press connectors.
  35. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the MagSafe port: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the MagSafe port: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the MagSafe port's press connector.
  36. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the lid angle sensor cable: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the lid angle sensor cable: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
  37. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the left cable covers: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the left cable covers: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the six screws securing the left cable covers to the frame:
    • Four 2.1 mm screws
    • One 2 mm screw
    • One 3.6 mm screw
  38. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the left cable covers: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers, or your fingers, to remove the three left cable covers.
  39. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the left speaker: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the left speaker: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the left speaker's press connector.
  40. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the left USB-C port: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the left USB-C port: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the left USB-C port's press connector.
  41. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the Touch ID sensor: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the Touch ID sensor: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the Touch ID sensor's press connector.
  42. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the keyboard: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the keyboard: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the keyboard: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  43. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the two ZIF connectors for the keyboard cables.
  44. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
  45. MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the fans: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the fans: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Disconnect the fans: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the right fan cable connector.
  46. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
  47. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the right fan cable by sliding it out from its socket on the logic board.
  48. MacBook Pro 16" 2021 Speaker Assembly Replacement, Reposition the right fan cable: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Reposition the right fan cable: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The right fan cable is lightly adhered to the logic board.
    • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
    • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
  49. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous disconnection and reposition procedure for the left fan cable.
  50. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the logic board: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the logic board: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the ten screws securing the logic board to the frame:
    • Six 3.8 mm screws
    • Four 4.6 mm screws
    • Use a 4 mm Hex driver to remove the two 6 mm screws securing the logic board to the frame.
    • Use a T6 Torx driver to remove the two 6 mm screws securing the heat sink to the logic board and frame.
    The parts list for this step links to the wrong part on an external site. It threw me off and it took some investigation to determine that this kit has the appropriate 4mm hex bit that you need: Mako Driver Kit - 64 Precision Bits
    Justin B - crwdns2934203:0crwdne2934203:0
    Two green screws nearest hinges were 5/32"hex head on my machine, listed here as T6.
    MotorMac - crwdns2934203:0crwdne2934203:0
  51. MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the logic board's clips: crwdns2935265:051crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Release the logic board's clips: crwdns2935265:051crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger between the right side of the logic board and the frame.
    • Pry up with the spudger to release the logic board from its clips.
    No clips encountered on this A2485 logic board (thankfully), LB is very delicate.
  52. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger between the bottom of the logic board and the frame.
  53. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the logic board: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the logic board: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the logic board: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift up the logic board by its right side to completely release the clips.
    • If it feels like it's not coming out, check that all the cables are disconnected.
    • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
    • Remove the logic board.
  54. MacBook Pro 16" 2021 Speaker Assembly Replacement, Reassembly information: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Reassembly information: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Reassembly information: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
    • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
    • Make sure all of the connectors are above the logic board before securing it back into the frame.
    • If you're having trouble positioning the connectors, use tape to keep them out of the way.
    There are several connectors on the right side that are not highlighted. Closely inspect all open ports to make sure a connector ribbon isn't hidden below.
    Thomas Hervey - crwdns2934203:0crwdne2934203:0
  55. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the screw covers: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the screw covers: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the screw covers: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to remove the four screw covers.
    Do you need to put these back on after you remove them?
    Jacob Leffler - crwdns2934203:0crwdne2934203:0
  56. MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the adhesive: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the adhesive: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the adhesive: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Both of the fans' cables are lightly adhered to the frame.
    • Insert the tip of an opening pick between the fan's cable and the frame.
    • Slice with the pick along the edges of the cable to separate the adhesive.
  57. MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the fans: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the fans: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx driver to remove the following screws securing the fans to the frame:
    • Four 3.3 mm T3 screws
    • Four 3 mm T5 screws
  58. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the fans: crwdns2935265:058crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the fans: crwdns2935265:058crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the fans: crwdns2935265:058crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the fans.
  59. crwdns2944590:059crwdnd2944590:061crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the trackpad: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the trackpad: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Ten 5 mm screws
    • Three 5.8 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  60. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the trackpad: crwdns2935265:060crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the trackpad: crwdns2935265:060crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the trackpad: crwdns2935265:060crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  61. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
  62. crwdns2944590:062crwdnd2944590:066crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the battery board: crwdns2935265:062crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Unfasten the battery board: crwdns2935265:062crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the two screws securing the battery board:
    • One 4.4 mm screw
    • One 3.8 mm screw
  63. MacBook Pro 16" 2021 Speaker Assembly Replacement, Battery removal information: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Battery removal information: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 14 total stretch release adhesive strips that secure the battery to the frame:
    • There are eight adhesive strips that are accessed from the bottom of the device.
    • There are six more adhesive strips accessed from the trackpad's location on the frame.
  64. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the stretch release adhesive: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the stretch release adhesive: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to grasp the black pull-tab on one of the adhesive strips.
  65. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • Repeat the process for all 14 stretch release adhesive strips.
    Can I change the speaker without removing the battery?
    Johnny Shek - crwdns2934203:0crwdne2934203:0
    Hi Johnny.
    You don't need to remove the battery! However, be careful when prying along the edge of the speaker since you can puncture the battery. I will update the guide accordingly.
    Alex Diaz-Kokaisl -
  66. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the battery: crwdns2935265:066crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the battery: crwdns2935265:066crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the battery: crwdns2935265:066crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the battery out of the frame to remove it.
  67. MacBook Pro 16" 2021 Speaker Assembly Replacement, Apply isopropyl alcohol: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Apply isopropyl alcohol: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Apply isopropyl alcohol: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a few drops of isopropyl alcohol along the edges of the speaker.
  68. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:068crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the right edge of the device upward to allow the isopropyl alcohol to work its way underneath the speaker.
    • Hold for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
  69. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While you're waiting for the adhesive to loosen, note where the adhesive is located underneath the speaker.
  70. MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the bottom adhesive: crwdns2935265:070crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the bottom adhesive: crwdns2935265:070crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the bottom adhesive: crwdns2935265:070crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick between the bottom of the speaker and the frame.
  71. MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:071crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement: crwdns2935265:071crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick upwards to separate the adhesive along the bottom length of the speaker.
    • Leave the pick in to prevent the adhesive from resealing.
  72. MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the top adhesive: crwdns2935265:072crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the top adhesive: crwdns2935265:072crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Separate the top adhesive: crwdns2935265:072crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick between the top of the speaker and the frame.
  73. MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the speaker: crwdns2935265:073crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the speaker: crwdns2935265:073crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2021 Speaker Assembly Replacement, Remove the speaker: crwdns2935265:073crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up with the pick to completely separate the top adhesive.
    • Remove the speaker.
    • If you're still feeling resistance, slice along the perimeter of the speaker or apply a few more drops of isopropyl alcohol.
    • Repeat the loosening and separating process for the other speaker.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
crwdns2935229:05crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
165,527 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:019,995crwdne2935297:0
crwdns2947412:011crwdne2947412:0
I only needed to replace one of the speakers, so I ended up foregoing removing the second fan, and also did not remove the trackpad or battery cells. It did make it a bit more challenging to access the speaker, but letting the isoprop sit a while and do its thing and then gently apply some lever action here and there between the chassis and the speaker got it loose enough that I could then get the spudger in underneath. Just be very careful not to use the battery cells for leverage if you've still got them in place!
And to save someone else from a heart attack after reassembling and then finding it doesn't turn on - apparently one has to hook it up to power after having had the battery disconnected for it to be willing to power up!
Johny Mattsson - crwdns2934203:0crwdne2934203:0
I wonder why there's so much adhesive in the assembly. Replacing the speakers had to be this much work. I wanna try it, but I'm afraid I might damage it. I'm currently weighing over the price of sending it to apple service centers vs. me doing it myself.
wedzmer.munjilul - crwdns2934203:0crwdne2934203:0
I need to replace only the left speaker, maybe there are fewer steps to replace it, I mean not to touch the right side of laptop.
Oh my God!! 73 steps just to replace a speaker.
DK Carrgo Inc - crwdns2934203:0crwdne2934203:0
Why is it that the speakers are located nearer the trackpad edge and not the keyboard edge? The grilles are next to the keyboard.. how does that work?
ADTC - crwdns2934203:0crwdne2934203:0
The body of the Mac is a part of the acoustic design of the speaker. The sound is designed to come out at the grille, even if it originates somewhere else. This has been the case going back for a long time. Look at iMacs, for example, also
Jerdon Kiesman -
After you remove the adhesive from the battery. I am assuming upon reassembly that it will not have adhesive to stick to the case. is that ok? or will the battery move around due to that?
sorry for the basic question, i just want to make sure i know what to expect upon reassembly.
It is no way necessary to remove the battery to change the speaker. I only need to replace my left speaker which had a really loud crackling noise. I ordered the replace adhesive but I didn't end up using it.
I followed the guide until step 63. The adhesive on the battery kept breaking, and I forgot to buy isopropyl alcohol, so I ended up just tearing the speaker apart, prying it off the metal and removing the leftover adhesive from the speaker with some makeup wipes. DO NOT DO THIS as you will spray some white powder from inside the speaker EVERYWHERE.
My new speaker came with adhesive already installed, so I just pressed it into place and went backwards in the guide. If you can tilt your MacBook a little towards the side of the speaker you want to change, you can make sure that the isopropyl won't touch the battery and you can completely skip that part of the guide. Also not sure it's even necessary to remove the trackpad.
But I was successful. My first iFixit fix - thanks for the guide, guys!
Oliver - crwdns2934203:0crwdne2934203:0
The white powder is really hard to clean out, especially since it gets stuck in all kinds of crevices! This is all a lot easier if you have compressed air on hand.
lslqtz -
After checking a series of speaker repairs, I found that the treble part of the 2021-2023 16-inch speakers is pressed under the motherboard... This makes it necessary to remove the motherboard before replacing the speakers, which greatly increases the complexity of repairs.
lslqtz - crwdns2934203:0crwdne2934203:0
Like @johnymattsson I only needed to replace one speaker. I skipped steps 55-66. Please note that you don't just need isopropyl alcohol, you need a needle applicator (see step 67). Lacking one, and lacking the ability to get one within the allotted time, I used the tube from my can of compressed air to dip into the bottle, plug the other end with my fingertip, transport to the laptop chassis, and then drip along the side of the speaker. The alcohol wicks extremely well along the side. Just make sure your laptop is tilted to keep the fluid draining in the right direction.
David Drum - crwdns2934203:0crwdne2934203:0
Regarding the 2 mm screws in steps 30 and 37, they are easy to identify later (at least in my laptop) because they have a unthreaded collar near the head. The 2.1 mm screws do not.
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 197
crwdns2942667:0crwdne2942667:0 9,251
