MacBook Pro 16" 2019 Speaker Replacement
crwdns2936621:0crwdne2936621:0
  1. MacBook Pro 16" 2019 Speaker Replacement, Open the Macbook: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Open the Macbook: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First step is opening up the MacBook. This was the most challenging step and maybe because it got me by surprise. The process works a bit different then older MacBooks. Watch this video if you are not aware of the process: https://www.youtube.com/watch?v=mHutSzIk...
    • Hint - Try pulling the bottom cover forward.
  2. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After opening up, disconnect the battery. Remove the cable and take out the big screw; this is to make sure there is no power running through.
  3. MacBook Pro 16" 2019 Speaker Replacement, The part: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, The part: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I'm going to replace the left and right speaker. I bought a few on AliExpress, since they were sold out on iFixit, however they arrived damaged. Hopefully they work.
  4. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Disconnect the speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On both sides, open up the connector and take out the cable.
  5. MacBook Pro 16" 2019 Speaker Replacement, Remove the Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Remove the Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Taking out the speaker is where it gets sketchy. It's hanging in there with VERY strong adhesive. Luckily, I'm going to replace the speakers and am not going to keep them so I can be rough. If you want to keep the speaker, I would advise another approach.
    This is great info. I'm going to try some heat on mine when I do it to try and soften the adhesive.
    DeeGee - crwdns2934203:0crwdne2934203:0
  6. MacBook Pro 16" 2019 Speaker Replacement, Take out the other side: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Take out the other side: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Same story on the other side. Wiggle your tool underneath and force it out.
  7. MacBook Pro 16" 2019 Speaker Replacement, Remove the adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Speaker Replacement, Remove the adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the adhesive and pulling it out is easy. If you can't pull it out, use a tool to carefully scratch it off the surface.
  8. MacBook Pro 16" 2019 Speaker Replacement, Clean the adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When cleaning the leftover adhesive, it's best to use an alcohol pad to clean it up as well as the general area.
    • Let the area dry before installing the speaker.
  9. MacBook Pro 16" 2019 Speaker Replacement, Ready for replacing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing both speakers, your MacBook should look like the one in the photo.
    • If you cleaned off adhesive in the previous step, make sure the area is clean/dry before moving on.
  10. MacBook Pro 16" 2019 Speaker Replacement, Glue: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step is optional if your replacement speaker does not have any adhesive.
    • Put adhesive around the outside of the speaker; use the glue sparingly.
    • Make sure you are using a glue that is specifically designed for computer repair or speaker repair. Here is a solvent that can be used for this guide.
    Has anyone had any luck with this tape? Tesa 61395 Tape
    Luca Doehling - crwdns2934203:0crwdne2934203:0
Dave Hakkens
crwdns2935283:001/03/16crwdne2935283:0
1.042 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
I just created an account to thank you,
I bought the speakers from ifix it, and I did follow your guide, and it worked perfectly.
so I joined here to thank you.
your guide helped me a lot. I appreciate the effort.
ALAA ALMAATOUQ - crwdns2934203:0crwdne2934203:0
appreciate that. Happy to hear its useful :)
Dave Hakkens -
This was very helpful... I managed to successfully replace mine... but unfortunately on step 5 I made the mistake of scuffing the battery, revealing the aluminum layer inside and it gave off a sweet smell (which i now understand is dangerous)
Painfully had to have the battery replaced for about 300$ (I'm in Nairobi, Kenya)
Maybe update the steps to avoid the nearby battery which is really sensitive.
Cheers
leemalu - crwdns2934203:0crwdne2934203:0
Thank you for this! I broke my speaker when following a different iFixIt guide, but your instructions saved the day. $49 is even for the replacement speaker from iFixIt is even cheaper than the deductible on my insurance plan through GetAkko, so this one was a no-brainer. Thank you, internet stranger!
Peter - crwdns2934203:0crwdne2934203:0
What are the tools that I’ll need to do this? Are they available on iFixit? Thank you!
[deleted] - crwdns2934203:0crwdne2934203:0
thanks A lot I just cleaned the loudspeaker and all the sound crackles whent away with the small metal dust.
I did not break the loudspeakers thanks to your good guide thanks for this !!!
no need to buy loudspeakers just clean the old ones with kapton tape . kiss my friends <3
Leo Etcheverry - crwdns2934203:0crwdne2934203:0
My clip to fasten the connector for the speaker broke. Is there an alternative way to ensure a solid connection to the speaker?
nick fruth - crwdns2934203:0crwdne2934203:0
I found a better way to remove the speakers (& batteries I guess?) without damaging them.
Usual warnings (re: batteries & components) apply.
"Tools":
- A blow dryer with a fast/high temp setting [a].
- 2 blue iFixit plastic picks [b].
Process:
1. Remove all of the sensitive components near the speakers. I removed the logic board for the right speaker, but left the batteries alone.
2. Heat up the top part of the UCA [c] just above the speaker.
3. Separate the speaker from the UCA starting from the top, i.e., the widest area of the speaker body (NOT the longest) with plastic picks. This helps prevent damage to the speaker. Trying to remove from the skinny portion or the length of the component WILL damage the speaker.
4. Repeat 2. & 3. until the speaker is free & clear. I did this 3x.
References:
a. Example: https://www.amazon.com/Conair-1875-Shine...
b. iFixit Opening Picks (Set of 6)
c. MacBook Pro 16" (2019) Upper Case Assembly and Battery
Enji Cooper - crwdns2934203:0crwdne2934203:0
A couple other things (ran out of characters in the comment above...):
1. With the picks I used a seesawing motion getting directly under the speaker, separating it from the UCA. Think of the picks like a pair of scissors cutting the glue connecting the speaker to the case.
2. Be patient and apply just enough force to separate the speaker from the UCA. If you apply too much force, it will damage the speaker. I know because I "yarded" the left speaker pretty hard with the metal pick (it was busted), and it broke pretty easily when I applied enough directed pressure.
Enji Cooper -
Same issue here. As the output of the sound I just tested Proxy Audio Device as the sound output and the sound is perfect again (but with a lot lower volume so I need to crank it up). So no need to order parts & fix it since it could be software related! Switching back to build in MacBook Pro speakers giving me the static sound again.
Robin Groenevelt - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 126
crwdns2936753:030crwdne2936753:0 730
crwdns2942667:0crwdne2942667:0 15,901
