MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement
    1. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
    2. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    1. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
    2. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    1. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove two Phillips screws securing the hard drive bracket to the upper case.
      • These screws are captive to the hard drive bracket.
    2. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the retaining bracket out of the upper case.
    3. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
    4. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the hard drive cable by pulling its connector straight away from the hard drive.
    1. MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Unibody Mid 2012 Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove two T6 Torx screws from each side of the hard drive (four screws total).
      • You'll need to transfer these screws to your new hard drive if you're changing drives.
      • If desired, peel the pull tab off your old hard drive and transfer it to the side of your new drive.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running. Many recent Macs may be able to use OS X Internet Recovery.
crwdns2935229:0242crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
515,868 crwdns2915208:0crwdne2915208:0
crwdns2935297:0406crwdne2935297:0
Staff
crwdns2935297:072,401crwdne2935297:0
crwdns2947412:031crwdne2947412:0
This made me feel like techie instead of a newbie!
djsnooze831 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, Im going to replace my mac hard drive. Looking at this guide it seems that I wont have too much difficulty in doing so, but do i need to format the new hard drive before I replace the old one? or can I just replace it and then format it when I boot it up for the first time?
Jamie - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
U don't need to format the hdd before you replace it with the ssd
Arfan Ali - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
will this fix my hard drive corruption.. i received a mac from ebay with no disk utility aswell
mshawn600 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the MacBook Pro mid-2012 15" and I have installed Samsung SSD 840 EVO 2.5" form factor drive and it fits fine. Really makes the MacBook fast.
Francisco Moreno - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 334
crwdns2942667:0crwdne2942667:0 219,529
