MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  2. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
  3. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  4. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  5. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
    • Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  6. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Walter Galan
703.039 crwdns2915208:0crwdne2915208:0
crwdns2935297:01.203crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 998
