MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable Replacement
  1. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Carefully peel the AirPort/Bluetooth ribbon cable off the top of the black plastic AirPort/Bluetooth housing.
  4. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off its socket on the AirPort/Bluetooth board.
crwdns2935229:012crwdne2935229:0
Walter Galan
705,764 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
Excellent guide, I found it very helpful. A tip for anyone out there who's WiFi stopped working or is glitchy. Before you replace the entire cable it might be worthwhile to check the connections first. My WiFi stopped working and I was about to order a replacement cable but figured I would make sure it wasn't just the cable coming loose. Using this guide I removed the cable, wiped the connections to clear any dust and put everything back together. WiFi now is working perfectly.
I think the connection from the cable to the logic board probably was jared loose due to it being in such close proximity to the bottom of the case.
Jachin Scott - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 19,269
