Replace a faulty fan to keep temperatures down.
            Remove the following ten screws securing the lower case to the upper case:
            Three 13.5 mm (14.1 mm) Phillips screws.
            Seven 3 mm Phillips screws.
            Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
            Remove the lower case and set it aside.
            Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
            Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
            Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
            Use the flat end of a spudger to disconnect the left fan connector from the logic board.
            Lift the left fan out of the upper case.
crwdns2935229:038crwdne2935229:0
Hey, I accidentally broke the connector from the logic board. Can it be fixed somehow? I tried to glued back together but it doesn't work.
Rosario, take that to a pro. Those things sometimes can be resoldered (Glue wont work), but it takes an experts eye and a steady hand. I got that eye, I dont have the hand, so as much as I can drive an oscilloscope with the best of them, my hand tremmor means I’d never trust a fix like that to myself.
