MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement
  1. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
    The number of screws listed here is wrong on my model. I had four of the smaller size.
    anonymous 1286 - crwdns2934203:0crwdne2934203:0
    Just to add to my comment above (I can't edit it because it's anonymous), my MacBook Pro is a mid-2015 15in model 2.8GHz (A1398; EMC2881). For the bottom case it uses six 3.1mm screws, and four 2.3mm screws at the clutch/hinge side of the MacBook Pro. I tried using a 3.1mm screw at the clutch/hinge end, as described in the main article, and they don't fit. It has to be four 2.3mm screws.
    agreed with above 1286...
    I have the Mid 2015/A1398/EMC 2909. the hinge end and two middle side screws used a 1.2x50mm screwdriver while the 'opening' end 4 screws used the T3 screwdriver. I guess different builds used different sized screws!!
    Tj Bennett -
    The instructions below have you basically taking ALL of the guts out of case. I’ve been doing my own apple repairs since before ifixit was a thing and this one is a handful. My battery was swelling and I wanted to remove it before it burst or bent the case so I took it out without having a replacement and it occurs to me that aside from using the solvent (liquid) to remove the adhesive, you could probably do this only taking the trackpad ribbon out. I have mine reassembled now and will research the best battery to buy but I think installation will take about 5 minutes. See if you can slip a plastic gift card under the battery and wag/saw the adhesive out without the solvent before you go through all of this. It might work. Note, don’t bend or put too much stress on the battery and certainly don’t puncture it…
    br1ansk - crwdns2934203:0crwdne2934203:0
    Battery Recall for 15-inch MacBook Pro Retina mid-2015. Check Apple’s site for recalls, and put in your serial number. They replaced my swelling battery for free, regardless of warranty.
    Steve -
    As we are only replacing the battery, you can safely skip steps 6-26 and 28-48, no need to disassemble the computer to pull out the battery. Use nail polisher remover I was able to pull a super bloated battery out, without disassembling my MacBook.
    John Sikking -
    I qualified for the recall. These bloated batteries are dangerous! DO NOT, UNDER ANY CIRCUMSTANCES, PUNCTURE THE BATTERIES!
    Thanks for the heads-up on the recall.
    Datajockeys -
    For battery replacement, I also chose NOT to remove everything, and NOT to use the solvent. I used an iFixit heating tube (from the iPad kits) to soften the adhesive from the keyboard face… NOT the battery itself! Used the iFixit cards. I have four, so the real work is possible BETWEEN two other cards — reduces the chance of puncturing the battery. Worked fine, took a little while, but no problems.
    Steve -
    I’m having a problem trying to get the screws off. I have a set of pentalobe screwdriver set. I found one screwdriver that fits perfectly on one set of screws, but I am unable to unscrew it. I tried using some force pushing the screwdriver into the screw, but nothing happens. Any suggestions?
    henry_k_wong - crwdns2934203:0crwdne2934203:0
    All the screws on mine are the same length for some reason.
    ccfman2004 - crwdns2934203:0crwdne2934203:0
    I would recommend the first step is: Run the battery down to ZERO before doing any next step. This reduces risk to you, people nearby, to the MBP and greatly reduces the risk of fire. Step 2 should be: Double-check that the battery is at zero.
    I like others listed below and on YouTube, disagree with these full tear down 70+ steps being the only focus. I get that I have to be careful not to get the acetone solvent near the speakers. I skipped 25+ steps by: tilting the MBP away from the speakers and using very little acetone solvent. More pressure with the plastic cards and only a few drops of solvent. While giving the full set of instructions is fine it should be very clear that you can (at the user’s own risk) do this.
    Kenneth Schleede - crwdns2934203:0crwdne2934203:0
    As above—I consider full disassembly to be far riskier to fragile cables and connectors than the risk for solvent spillage. I did steps 1-5 and 46-74. No issues. I HIGHLY recommend the iFixit magnetic Project Mat. It’s a white marker board surface gridded into squares and invaluable for labeling part sizes/steps in disassembly.
    philtrit - crwdns2934203:0crwdne2934203:0
    As above too. I benefitted from the advice. From step 51 onwards, I found a easier way using tip from China battery seller. Use a 2” width plastic scraper/plastic paint scraper to poke under the battery. Use moderate strength to poke and avoid rough handling of the battery so as not to puncture it. There is no need to pry the battery to avoid stressing it, just use a firm poking action under the battery and the double sided tape adhesive will yield. After 5 min of such poking, the entire battery pack can be removed without the hassle of pouring the adhesive remover from step 51 onwards. Get a scraper with a stronger handle so that it is more comfortable to poke.
    https://www.aliexpress.com/item/32889670...
    Emma Pn - crwdns2934203:0crwdne2934203:0
    Heads up as you go…we (husband/wife team) had a notebook that when screws/covers were removed, we marked the step # and actually taped the screws into the notebook noted by the step number. This was very helpful on reassembly and we knew we would be using the exact screw into the original screw hole.
    Ann Brainard - crwdns2934203:0crwdne2934203:0
    After replacing the batteries myself, I wouldn’t even consider doing it again. Not that it’s difficult to do—that’s not the issue. The issue is aftermarket batteries. I’ve been using notebooks for well over 30 years, and never had satisfaction with aftermarket batteries.
    Modern lithium batteries are an amazing technological feat, but a dangerous one. So even putting aside that I’ve never found any aftermarket batteries with quality anywhere near original, I learned “cheap” aftermarket lithium batteries are downright dangerous.
    After doing research into what’s involved with manufacturing lithium batteries, I know there are so many corners to cut, you’ll end up with junk regardless of what you pay.
    A week after replacing my batteries with those from iFixit, they showed clear signs of failure. Thank goodness iFixit refunded my money.
    After having Apple replace my batteries, everything is back to like-new. For my $199, I got not only excellent batteries, but a new keyboard and trackpad as well. That’s it’s done!!!
    AnnoniMoose - crwdns2934203:0crwdne2934203:0
    Which of the following companies make their own LiIon cells, Apple, Dell, DeWalt, Milwaukee, Tesla, Trek? Ans: NONE OF THEM. All these companies buy their LiIon cells from companies that will sell to iFixit or any other legitimate company. If you want quality, either do the research or pay through the nose for OEM. And note the Apple battery recall. Apple messes up too.
    Bartwick -
    I found an Apple Support link that said MBP battery replacement was $199, but the 2 Apple Stores near my house would not provide any appointments. Instead, I scheduled an appointment with and “Apple Authorized Service Provider” & that repair center quoted about $750 to replace the battery.
    I refused, went home, & opened a chat with Apple Support.
    After a lengthy & painful chat session where the Apple tech didn’t want to provide a battery replacement quote (he feared other issues with the MBPr), he finally gave me an Apple price of just under $650 to replace the battery.
    Did you go into an Apple store, or mail it in? I’m struggling to reconcile a price of $199 to get a battery + keyboard + trackpad against what I was just quoted 2 weeks ago. The new track pad & keyboard might have been due to repair tech error. i.e. they trashed those repairing your batter & had to toss them in.
    Bartt.Shelton@gmail.com - crwdns2934203:0crwdne2934203:0
    I took mine in after being quoted for a $199 replacement of battery and keyboard, only to have the repair refused as they found a "water sensor" triggered and now I'm left with my AUD$5,000 laptop with messed up keys. Shame on me for not getting this repaired during COVID while under warranty. This is the first time I've truly been disappointed in Apple, but suppose it was bound to happen someday. I was quoted US$ 1479 to replace the battery and keyboard and the sensor (likely the logic board is replaced as well) if I were to send it in to the US repair center. Any chance these sensors can be triggered by humidity?
    C0RT - crwdns2934203:0crwdne2934203:0
    I 1000% recommend watching this video and performing the battery replacement without all these steps from this guide and without using the acetone solvent. https://www.youtube.com/watch?v=ImonCWcc... (15" inch Retina MacBook Pro A1398 Mid 2015 Disassembly Battery Replacement Repair)
    The video is narrated well and the guy goes slow and zooms in where appropriate. Instead of removing all components, he simply removes the track pad cable, battery cable, and unscrews two of the speaker screws on each side. From there, you can lift up the speaker arms where the video guy uses a thin pry tool to push through the sticky tape. No solvent is needed except for residual sticky stuff leftover.
    Instead of the thin pry tool, I just used the plastic cards that came with this ifixit kit. It takes a little force and wiggle/jiggle so take your time using the corner of the card to start.
    This method makes a difficult 2-3hr job into a much easier 1hr job.
    Spencer - crwdns2934203:0crwdne2934203:0
    +1 for this approach! I watched the video that Spencer mentioned. It took me a little over an hour, and it was stress-free. https://youtu.be/ImonCWcc1xk
    Chris Wicklas -
    Another +1 - I followed the video pretty exactly (after having already gone through steps 1-5 here). I'm not sure it's necessary to clean off the adhesive residue as thoroughly as he demonstrates in the video, but the instructions were clear and the end results were good - trackpad still working fine and new battery already charged to 50%.
    Jeff Zinn -
    Glad I read these comments before plunging into the iFixit instructions.
    +1 for skipping the iFixit instructions and using the youtube video linked by Spencer.
    I followed the instructions and had my battery replacement done succesfully.
    Instead of the metal spatula like thing he used - I used the plastic ifixit credit card things that came with my battery kit.
    It took about 15 minutes of wiggling under the battery to free it from the adhesive but it wasn't too bad.
    I did remove the residual adhesive as he indicated with isopropyl alcohol - but after finishing my installation I realized it was completely unnecessary. You can install the new battery over the residual gunk and skip that step.
    picardo -
    Yes! This YouTube tutorial works great and it was really easy to replace the battery. I needed about 75 minutes.
    Perform steps 1-5,
    Then skip to step 41.
    In 41 + 43 do not unscrew the red marked screws.
    In 42 an 45 just lift the speakers, do not remove them.
    Skip 44
    Up from 53, I did not use the glue remover, the plastic cards were enough.
    In step 63 watch out to start from the middle. This prevents you from peeling up the lower „platform“.
    Great job :-)
    weekendiac -
    It’s now February 2024, and the batteries Apple installed have all swelled up just like the originals. Doing a bit of research on the manufacturer, Simplo, I no longer trust them either. Microsoft used Simplo in their tablets, with countless users complaining about bad batteries. A few days ago, I read a post saying Apple now charges $250 instead of the $200 I paid less than three years ago. WOW! Even if Apple would replace my batteries, there’s no way I’m going that route again. Too bad my MacBook won’t boot without batteries. I don’t need them; I don’t want them. I also don’t want a newer MacBook. What to do???
  2. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    If you buy the entire kit, make sure you use the opening tool! I cut both of my index fingers trying to slide it off.
    Catherine Nath - crwdns2934203:0crwdne2934203:0
    Additionally, this is an “opportunity” to clean the cooling fans - and any other obvious dust magnets - with a can of compressed air. On the laptop I worked on, the cooling fans had sufficient dust to not “spin” freely - showing signs of “drag”. After blasting each cooling fan with compressed air (including from the exhaust vent side, as hitting the fins alone wasn’t adequate), they both spin freely now. No obvious signs of battery swelling on mine, but lack of adequate airflow could have been a factor with original battery aging/failure.
    Zathras - crwdns2934203:0crwdne2934203:0
    Good opportunity to give a good clean out. Air duster and small clean paint brush on plastic surfaces to clean up essential vents and fans. You can load fan monitor and control software to see what your your system is doing and how it improves with a clean up.
    Robin Razzell - crwdns2934203:0crwdne2934203:0
  3. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
    pretty hard to put it back, so I just remove the clips on the upper case....
    jamiegan835 - crwdns2934203:0crwdne2934203:0
    The trick to putting it back on is to guide your fingers to the same level as the clips, and then when you put the case down move your hand from the left side of the case to the right side of the case; applying pressure when you reach the area where the clips are.
    Aaron Freidus - crwdns2934203:0crwdne2934203:0
    Impossible to put those peds into the upper case clips! It just does not hold there, it fits but just does the ‘click’ sound and goes back. Is it possible to buy those clips as spare part? Thank you for help.
    Lopez Loku - crwdns2934203:0crwdne2934203:0
    Same for me. It just never clips, regardless of the precision and the amount of force I apply.
    Vadym Borodin - crwdns2934203:0crwdne2934203:0
    I also think I stripped the screws holding the clips in place. Does anyone know what screw characteristics should I look for as a replacement?
    Bloated battery had already popped my clips.
    jecottrell65 - crwdns2934203:0crwdne2934203:0
  4. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Battery Connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the sticker covering the battery connector.
    You only need to remove the tape to the edge of the flap. This is enough to be able to pry the battery connector up.
    Note that the photo is taken from the hinge side - the other way to the photo in step 3
    Toby Thurston - crwdns2934203:0crwdne2934203:0
    I chanced it, didnt disconnect the battery and all is well even after giving the insides a good vacuuming before changing the SSD.
    Dermot O Logical - crwdns2934203:0crwdne2934203:0
    It is just the top layer of tape that you want to lift, you need to seperate it from the bottom layer.
    Kelv - crwdns2934203:0crwdne2934203:0
    You don’t actually need to remove the tape or even peel it off at all. Just pull up the battery connector up with the tape still attached.
    AJ Lorenzo - crwdns2934203:0crwdne2934203:0
    pay attention that the macbook in this picture is presented the “wrong side”: if you accidentally remove the tape covering the trackpad cable and thereby also take the trackpad cable out of the zif-socket, your keyboard and trackpad won’t work anymore. putting the trackpad cable back into the (tiny) socket will fix the issue though.
    sam - crwdns2934203:0crwdne2934203:0
  5. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    why is this necessary to remove a hard drive?
    Lawtay - crwdns2934203:0crwdne2934203:0
    @lawrencetaylor On any electronics repair, you need to disconnect all sources of power before you start. It’s a basic safety precaution and also removes the risk of accidentally shorting a connection somewhere (which can potentially kill your MacBook).
    Jeff Suovanen -
    Picture doesn’t match the computer. Hard to tell which connector to disconnect
    James Mitchell - crwdns2934203:0crwdne2934203:0
    Hi James, are you sure you have the correct guide for your machine? Try using our MacBook Identification tool.
    Sam Goldheart -
    Habe den Akkustecker beim putzen abgemacht um keinen Stromschlag zu kriegen, jetzt wieder eingebaut. Nun habe ich folgendes Problem: Akku wird geladen, aber steigt niemals ueber % und manchmal geht er trotz Anschluss an das Stromnetz einfach aus. Hat da jemand eine Idee?
    paul - crwdns2934203:0crwdne2934203:0
    I used the identification tool and can confirm what James is seeing. The picture doesn’t match for this step. There is no piece with visible holes punched in it.
    Joshua McFarland - crwdns2934203:0crwdne2934203:0
    There is an extra piece of plastic on the connector, you might want to peel that off too. It’s not in the pictures.
    Ellie B -
    There is a battery cover with two T5 screws that must be removed before prying on the connector.
    Dennis Newton - crwdns2934203:0crwdne2934203:0
    Hi Dennis,
    Thanks for bringing this up! I’ll work on verifying this and adjust the guide as needed.
    Arthur Shi -
    My battery connector had another layer of plastic on it that I removed first
    For an A1398, the screws on the adjacent cover were T6, not T5; one of the tips in the battery kit was suitable.
    After separating the battery connector, I took the addd precaution of placing a folded post-it between the connector bank and the socket.
    Matt Fisher - crwdns2934203:0crwdne2934203:0
    You can also use a plastic tool to hold back the battery connector. My connector was under the plastic tab and had no screws. You may need to check the build version as there are a number of A1398 versions.
    When you install the new battery, it may look like the holes in the connector need to be slid on to the connector toward the rear of the mac. I tried bending the cable to make it work. This could damage the cables. You really need only push directly downward on the connector, as you pulled up on it to remove it initially. It will pop into place with a little pressure, just make sure it's lined up properly.
    Jeffrey Andrews - crwdns2934203:0crwdne2934203:0
    I had to use quite a lot of pressure to make the connector on my new battery pop all the way down. I thought it was down already when it was only half way, as I was afraid to use too much force. Maybe it varies between different battery brands, but just make sure that the connector should go all the way down and not have a gap between the two parts.
    Magnus W - crwdns2934203:0crwdne2934203:0
    " …ensuring that the battery connector doesn't accidentally make contact with the logic board."
    You appear to assume that everyone knows which item is the logic board. I can attest that not everyone does. Clarity here would be helpful.
    Mark - crwdns2934203:0crwdne2934203:0
    If you don't know what the/a logic board is, you probably shouldn't be opening devices.
    Art Hackett - crwdns2934203:0crwdne2934203:0
    Art Hackett. Not useful. This guide is for laypeople. Nobody is supposed to know much of anything. That's the point of the guide and the existence of iFixit. You could have used that time to explain what the logic board is for people who are already here anyway.
    Anyway onward and upward. If you don't know what a logic board is and you're here. https://www.google.com/search?q=macbook+...
    There, now you're an expert like Art.
    fixedtit - crwdns2934203:0crwdne2934203:0
  6. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Left Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Left Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the left rubber cover up off the fan and fold it out of the way.
  7. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following three screws securing the left fan to the logic board:
    • One 3.6 mm T5 Torx screw with a wide head
    • One 5.0 mm T5 Torx screw with a 2.0 mm long shoulder
    • One 4.4 mm T5 Torx screw
    the yellow one may not go back in during reassembly unless the board is perfect. Stripped mine in the effort - put back together without this screw :(
    Paul Forgey - crwdns2934203:0crwdne2934203:0
    I ran in a similar misalignment so had to bend the top left loop a bit to make it fit.
    Not a big issue, but better to lay it in and check the alignment of all screw holes (and adapt if necessary) before putting the screws in.
    I saw my replacement part had already a bit of paint missing at the top left and bottom right holes, so I assume it is a refurbished or sourced part, so a bit of tweaking may be necessary. BTW, the fan works perfectly, no more annoying clicking noises.
    Maarten S - crwdns2934203:0crwdne2934203:0
    The red-coded one is the most mushroom-shaped screw this time. (biggest, flattest screw head)
    Howard Graff - crwdns2934203:0crwdne2934203:0
  8. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
    • The fan cable may be adhered to the logic board—to avoid tearing the cable, gently peel it up while lifting the fan.
    • Remove the fan.
crwdns2935229:047crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
502,825 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2931471:0135crwdne2931471:0
crwdns2935297:016,817crwdne2935297:0
First repair job. After 5 years of use my laptop was getting heated quicker than the oven and making that antique modem noises. With 2 screwdrivers and a plastic card to pry the connectors cleaned all the dust inside the case and the fans following the fan replacement guides without any trouble. Huge thanks to Andrew for this very detailed page! Btw, if you intent to reuse the fans, be careful with the connector cables. They are not flexible, they bent easily and might break.
Furkan Karagöz - crwdns2934203:0crwdne2934203:0
Thank you so much - I used this to access and clean (but not replace) the fan.
CCC - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 157
crwdns2942667:0crwdne2942667:0 32,020
