Input, Output, Sideput. Whatever kind of puting you will be doing, a faulty I/O board cable is going to severely limit the functionality of your MacBook Pro. This guide will show you how to replace it.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Peel back the sticker covering the battery connector.
Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
Remove the left connector cover.
Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
Remove the right connector cover.
Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
Peel the I/O board cable up from the adhesive securing it to the fan.
Remove the cable.
