Use this guide to install an I/O board containing a USB 3.0 port, HDMI port, and SDXC card reader.
            Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
            Eight 3.0 mm
            Two 2.3 mm
            Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
            Set the lower case aside.
            Peel back the warning label covering the battery connector.
            Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
            Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
            Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
            Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
            Slide the spudger underneath the length of the cover, releasing the adhesive.
            Lift the cover and flip it back so that you can access the cables underneath.
            Use your fingers to pull the AirPort/Camera cables up off the fan.
            Carefully de-route the cables from the plastic cable guide.
            Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
            In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
            Remove the I/O Board cable from the MacBook Pro.
            Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
            Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
            Pull the AirPort card parallel out of its connector on the logic board to remove it.
            Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
            Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
            Remove the following three screws securing the right fan to the logic board:
            One 4.4 mm T5 Torx screw
            One 3.9 mm T5 Wide Head Torx screw
            One 5.0 mm T5 Torx screw with 2 mm collar
            Lift and remove the right fan out from the MacBook Pro.
            Use the point of a spudger to flip up the locking mechanism on the I/O board connector.
            Flip the spudger around and use the flat end to slide the I/O cable out of the connector.
            Remove the two 3.1 mm T5 Torx screws from the I/O board.
            Lift the I/O board straight up, out of the device.
            With the flat of a spudger, release the clip on the right side of the plastic I/O cover.
            After releasing the clip, you can easily lift the cover off of the board.
crwdns2935229:010crwdne2935229:0
