Restore sound to your laptop by replacing the speakers.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
Two 10 mm T6 Torx screws on either side of the RAM slot.
Four 14.5 mm Phillips screws along the hinge.
Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Use the flat end of a spudger to disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Remove the following 4 screws:
Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
One 4.7 mm silver T6 Torx screw from the top left corner of the drive.
One 6.2 mm black Phillips screw at the top right corner of the drive.
Lift the optical drive up and out of the computer.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Disconnect the iSight and display data cables from the logic board by sliding them straight back out of their connectors, removing tape as necessary.
Disconnect the eight indicated connectors by placing a spudger beneath the wired side of each one and lifting up.
Remove the foam bumper from the top of the right hinge of the display.
Remove the silver 9.5 mm T6 Torx screw securing the ground loop in the display data cable to the casing.
Remove the single black 6 mm T6 Torx screw securing the upper portion of the logic board to the lower case.
Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
Remove the following 15 screws:
One 4.4 mm black Phillips screw to the right of the ram slot.
Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the left fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the left fan up.
Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
Remove the right fan from the computer.
Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
Lift the heat sink out of the computer.
Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
Remove the left fan from the computer.
Disconnect the two antenna cables attached to the Airport Extreme card.
Deroute the Airport antenna cables from their channel in the left speaker.
Remove the single black T6 Torx screw located just above the Airport Extreme card.
Lift the small silver metal retaining bracket up and out of the computer.
Lift the Airport Extreme card up and slide it out of its connector.
Peel up the orange hard drive cable from above the ExpressCard cage.
Disconnect the speaker cable from the corner of the left I/O board.
Carefully peel up the black adhesive tape securing the speaker cable along the rear edge of the lower case.
Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
Remove the single black T6 Torx screw securing the right speaker to the lower case.
Use a spudger to pry up the right speaker from the lower case.
Remove the speakers from the computer.
Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
Lift the clear plastic shield off the left ambient light sensor.
Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
Speakers remain.
crwdns2935229:012crwdne2935229:0
I noticed that there were not any actual instructions for the Thermal Paste application as recommended. Other than that the instructions were spot on! - Makes repairs much more affordable when I can do it myself. CERTAINLY invest in the spudger if you don't have one though. There really is no other way you can be careful enough when dealing with the logic board and connections.
One other tip - Print out the instructions - get some clear tape and then tape down each screw to the instructions. That will make it much easier to keep track of where everything is going as well as ensuring you don't lose any of the tiny little screws or get one in the wrong spot.
