MacBook Pro 14" 2021 Logic Board Replacement
  1. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" 2021 Logic Board Replacement, Unclip the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unclip the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" 2021 Logic Board Replacement, Release the right clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the right clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the right clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" 2021 Logic Board Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" 2021 Logic Board Replacement, Release the sliding clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the sliding clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the sliding clips: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. MacBook Pro 14" 2021 Logic Board Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the trackpad cable bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 14" 2021 Logic Board Replacement, Remove the trackpad cable bracket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the trackpad cable bracket: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the trackpad cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the trackpad cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" 2021 Logic Board Replacement, Reposition the trackpad cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Reposition the trackpad cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery board: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  16. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 14" 2021 Logic Board Replacement, Remove the data cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the data cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the battery connector: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
  19. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the antenna bar's connector bracket: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the antenna bar's connector bracket: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  21. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the antenna bar: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the antenna bar: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the screen cable covers: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the screen cable covers: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the four 2.1 mm screws securing the screen cable covers.
  24. MacBook Pro 14" 2021 Logic Board Replacement, Remove the screen cable covers: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the screen cable covers: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
  25. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the screen cables: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the screen cables: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the screen cables: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
  26. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous disconnection process for the remaining press connector at the top left of the logic board.
    • Don't pry against the surface-mounted components near the press connector.
  27. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the microphone cable connector.
  28. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
  29. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the microphone cable by sliding it out from its socket on the logic board.
  30. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the right-side cable covers: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the right-side cable covers: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the nine 2.1 mm screws securing the right cable covers to the frame:
  31. MacBook Pro 14" 2021 Logic Board Replacement, Remove the right cable covers: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the right cable covers: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the five right cable covers.
  32. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the right speaker cable.
  33. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right speaker cable.
  34. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the right speaker cable by sliding it out from its socket on the logic board.
  35. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the headphone jack: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the headphone jack: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the headphone jack's press connector.
  36. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the right USB-C ports: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the right USB-C ports: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the right USB-C ports: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the right USB-C ports' press connectors.
  37. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the MagSafe port: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the MagSafe port: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the MagSafe port's press connector.
  38. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the lid angle sensor cable: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the lid angle sensor cable: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
  39. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the left cable covers: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the left cable covers: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the four screws securing the left cable covers to the frame:
    • Two 2 mm screws
    • Two 2.1 mm screw
  40. MacBook Pro 14" 2021 Logic Board Replacement, Remove the left cable covers: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the left cable covers: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the two left cable covers.
  41. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the left speaker: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the left speaker: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the left speaker cable.
  42. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the left speaker cable.
  43. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the left speaker cable by sliding it out from its socket on the logic board.
  44. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the left USB-C port: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the left USB-C port: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the left USB-C port's press connector.
  45. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the Touch ID sensor: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the Touch ID sensor: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the Touch ID sensor's press connector near the top left of the device.
    • The Touch ID sensor cable is adhered to the frame. If the adhesive doesn't separate when you disconnect the press connector, slide an opening pick under the cable to separate it.
  46. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the keyboard: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the keyboard: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the keyboard: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  47. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connectors for the keyboard cables.
  48. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
  49. MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the fans: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the fans: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Disconnect the fans: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the right fan cable connector.
  50. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
  51. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the right fan cable by sliding it out from its socket on the logic board.
  52. MacBook Pro 14" 2021 Logic Board Replacement, Reposition the right fan cable: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Reposition the right fan cable: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The right fan cable is lightly adhered to the logic board.
    • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
    • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
  53. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous disconnection and reposition procedure for the left fan.
  54. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four black screw covers from the logic board.
  55. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the logic board: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the logic board: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the logic board: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T5 Torx driver to remove the 11 screws securing the logic board:
    • Four 3.6 mm screws
    • Two 4.5 mm screws
    • Two 5.2 mm screws
    • Two 3.8 mm screws
    • One 3.9 mm screw
  56. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T6 Torx driver to remove the three screws securing the logic board:
    • Two 4.7 mm screws
    • One 5.7 mm screw
  57. MacBook Pro 14" 2021 Logic Board Replacement, Release the logic board's clips: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Release the logic board's clips: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger between the right side of the logic board and the frame.
    • Pry up with the spudger to release the logic board from its clips.
  58. MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger between the bottom of the logic board and the frame.
  59. MacBook Pro 14" 2021 Logic Board Replacement, Remove the logic board: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the logic board: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the logic board: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift up the logic board by its right side to release it from its alignment pegs.
    • If it feels like it's not coming out, check that all the cables are disconnected.
    • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
    • Remove the logic board.
  60. MacBook Pro 14" 2021 Logic Board Replacement, Reassembly information: crwdns2935265:060crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Reassembly information: crwdns2935265:060crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Reassembly information: crwdns2935265:060crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, perform the following:
    • Make sure all 18 connectors are above the logic board before securing it back into the frame.
    • If you're having trouble positioning the connectors, use tape to keep them out of the way.
    • Hold the rubber spacers out of the way so the fins can drop into their recesses.
    • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
    • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
  61. MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the heat sink: crwdns2935265:061crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Unfasten the heat sink: crwdns2935265:061crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the logic board upside-down so that the heat sink screws face upwards.
    • Use a T5 Torx driver to remove the four 3.9 mm screws securing the heat sink to the logic board.
    • Gently hold the screws as you remove them, as the tension brackets may eject them.
    • During reassembly, loosely tighten these screws, then align the brackets and heatsink before fully tightening them in an X-pattern.
  62. MacBook Pro 14" 2021 Logic Board Replacement, Remove the heat sink brackets: crwdns2935265:062crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the heat sink brackets: crwdns2935265:062crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the heat sink brackets.
  63. MacBook Pro 14" 2021 Logic Board Replacement, Remove the heat sink: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Logic Board Replacement, Remove the heat sink: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Thermal Paste
    $24.95
  64. MacBook Pro 14" 2021 Logic Board Replacement, Only the logic board remains: crwdns2935265:064crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're now left with the logic board.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
crwdns2935229:011crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
214.551 crwdns2915208:0crwdne2915208:0
crwdns2935297:01.044crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023.765crwdne2935297:0
crwdns2947412:05crwdne2947412:0
I understood that on these models the screen is paired with the original motherboard, has anyone had a display problem after replacing the motherboard?
Ludovic - crwdns2934203:0crwdne2934203:0
yes. this is fixed sinced macOS 15.2
Patrick Hannappel-Fechner -
This guide is great! Thanks so much for this clear method. One question: Does anyone have a reliable way to connect the press connectors? Example on Step 44 I find I have to fight and guess every time I need to reconnect them. There is no way to see easily, when they make a perfect contact.
Handel Callender - crwdns2934203:0crwdne2934203:0
I share your concern about press connectors, that can be very tricky and they always come in narrow, deep and fragile place on the motherboard.
Gredin973 -
BE CAREFUL WITH TOUCH ID!
I'm trying to repair a MacBook Pro, the guide in step 45 says just to disconnect the Touch ID
Before you dismount totally the logic board, under the board the Touch ID stills connected, be careful to move aside the cable and be sure it's not moved with the board
Due to this mistake I broke the Touch ID cable
Luis - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 241
crwdns2936753:030crwdne2936753:0 1,116
crwdns2942667:0crwdne2942667:0 32,879
