Apple introduced its M1 Pro/Max processors in the 2021 MacBook Pros. How do these new in-house SoCs change the rest of the logic board’s silicon? Check out this chip ID guide to find out!
Hats off to our community member C. Chin for contributing to this!
IC Identification, pt. 1:
Apple APL1103 M1 Pro system-on-a-chip (SoC)
Samsung K3LKYKY0EM-ZGCP 8 GB LPDDR5 SDRAM Memory (16 GB total)
Kioxia KICM225UZ0460 128 GB NAND Flash Memory
Apple APL1098/343S00515 Power Management
Apple 338S00600 Power Management
Kinetic Technologies MCDP2920 DisplayPort-to-HDMI Converter
Genesys Logic GL9755A Card Reader Controller
IC Identification, pt. 2:
Intel JHL8040R Thunderbolt 4 Retimer
Macronix MX25U6472F 64 Mb Serial NOR Flash Memory
Winbond W25Q80DVUXIE 8 Mb Serial NOR Flash Memory
Renesas RAA225701C ? Synchronous Step-Down Converter
Analog Devices LT86422 Synchronous Step-Down Converter
Texas Instruments TPS62130B Step-Down Converter
Texas Instruments TPS62180 6 A Synchronous Buck Converter
IC Identification, pt. 3:
Texas Instruments TVS2200 Surge Protection
ON Semiconductor FPF2495CUCX Load Switch
Texas Instruments Load Switch (likely)
ON Semiconductor NCV8160AMX500TBG 250 mA / 5.0 V LDO Regulator
Nexperia 74AVC2T45 Dual-Bit Voltage Level Translator/Transceiver
Texas Instruments SN74AXC1T45 Single-Bit Bus Transceiver
Nexperia 74AUP1G07 Single Buffer
IC Identification, pt. 4:
Texas Instruments LSF0102 2-Ch. Multi-Voltage Level Translator
Nexperia LSF0101 1-Bit Multi-Voltage Level Translator
Texas Instruments SN74AUP2G07 Dual Buffer
Texas Instruments SN74LVC1G07 Single Buffer
Nexperia 74AUP1G17 Schmitt Trigger
Nexperia 74AUP1G08 Single AND Gate
Kioxia KICM225VF9081 128 GB NAND Flash Memory
USI 339S00912 Bluetooth/WiFi Module
NXP Semiconductor SN210V NFC Controller w/ Secure Element
Texas Instruments CD3217B12 USB Type-C Port/Power Delivery Controller
Renesas ISL9240 Li-Ion Battery Charger
Winbond W25Q80EWUXIE 8 Mb Serial NOR Flash Memory
Interesting. Not seeing any mention of a USI 339S009912 wifi combo module, in fact, USI Global’s website doesn’t appear to document any 802.11ax compatible products, or BT 5.0. Guess they might just be custom-packaging a BCM chipset.
Interesting. I’m not seeing any mention of USI 339S00912 online, and USI Global’s website doesn’t mention any identified products with 802.11ax or BT 5.0 support. I guess they might just be custom-packaging a BCM chipset for Apple.
One of the CD3217B12 on the left side is actually a CD3218B12ACE2, most likely the very top one. The CD3218B12ACE2 is responsible for the MagSafe 3 connector.
Renesas Power Phase PWM Controller
Cirrus Logic CS42L84A Audio Codec
Texas Instruments SN012776B0 Audio Amplifier
Renesas RAA209100 Boost Regulator (likely)
Texas Instruments LP8548B1 Backlight LED Driver
Texas Instruments TUSB2E22 USB 2.0 Dual Repeater (likely)
Texas Instruments LP8548B1 is the Keyboard Backlight Driver here. It was used as both LCD and keyboard backlight driver in previous Macbooks, but not anymore. The new LCD backlight driver is RAA209100. It drives MOSFETs on the other side of the board (same location) connection directly to the LCD connector. The listing could be updated accordingly.
Texas Instruments INA190A3 Current Sense Amplifier
Texas Instruments INA190A4 Current Sense Amplifier
Maxim Integrated MAX9620 1.5 MHz Rail-to-Rail Input/Output Operational Amplifier
ON Semiconductor NCS333ASQ3T2G Single Operational Amplifier
Dialog Semiconductor Mixed Signal Array (likely)
NXP Semiconductor PCAL6416A 16-Bit I/O Expander
Analog Devices ADG1422BCPZ Dual SPST Analog Switch
Texas Instruments REF3325 2.5 V Voltage Reference
Texas Instruments TLV75801P 500 mA / Adj. LDO Regulator
Texas Instruments TLV75533P 500 mA / 3.3 V LDO Regulator
Texas Instruments LP5907SNX-3.0 250 mA / 3.0 V LDO Regulator
ON Semiconductor NCP163BMX180TBG 250 mA / 1.8 V LDO Regulator (likely)
Texas Instruments TLV70733P 200 mA / 3.3 V LDO Regulator
Texas Instruments TPS7A201825 200 mA / 1.825 V LDO Regulator
IC Identification, pt. 5:
Nexperia 74AVC4T774 4-Bit Translating Transceiver
Nexperia 74AUP1T45 Translating Tranceiver
Nexperia LSF0101 Single-Bit Multi-Voltage Level Translator
Texas Instruments SN74AUP1T34 Single-Bit Voltage-Level Translator
IC Identification, pt. 6:
Nexperia 74AXP1T34 Buffer
Nexperia 74AUP2G07 Dual Buffer
Nexperia 74LVC2G32 Dual OR Gate
Texas Instruments SN74AUP1G32 Single OR Gate
Texas Instruments TPD4S311A USB Type-C Port Protector
IC Identification, Sensors:
Bosch Sensortec BMI282 6-Axis MEMS Accelerometer/Gyroscope
IC Identification:
STMicroelectronics STM32L4P5QG 32-Bit ARM Cortex-M4 Microcontroller w/ 1 MB Flash
Broadcom BCM5976C1 Touchpad Controller
Maxim Integrated MAX11390A A/D Converter (likely)
Monolithic Power Systems MP6519 5A H-Bridge Current Regulator
Texas Instruments TPS3831G18 1.67V Voltage Supply Monitor
Texas Instruments TPS22915 Load Switch
Bosch Sensortec BMA282 3-Axis Accelerometer
Texas Instruments TMP461 Temperature Sensor
crwdns2947412:010crwdne2947412:0
Why so many LDO regulators? Aren't they very inefficient?
In practise, the efficiency of an LDO regulator is dependent on how much voltage it is dropping. While operating, an LDO is effectively a resistor that varies in real-time to ensure its output voltage stays stable despite changes in load current.
Power = I (current) x V (voltage)
Since an LDO is a resistive element, yes, it burns off energy as heat in this process. So an LDO dropping 18V to 5V could be very inefficient, more so when driving a higher current load as shown by the formula above. However, if an LDO is used to generate a 3.3V rail from a 5V rail, it is dropping just 1.7V, resulting in less power dissipation for the same load current.
You’re right, using an LDO for a large voltage drop is not good electrical design. But LDOs have excellent noise rejection performance, meaning they can take a noisy rail from a switching buck/boost converter with lots of transient or high-draw components on it, and create a much cleaner rail for lower-current, more sensitive devices. This is what I expect Apple’s doing.
iEvan -
LDOs drop the difference in voltage as heat, yes - hence the voltage difference between input and output determines the efficiency (eg a 3.0v LDO fed by 6.0v is 50% efficient).
In many cases where LDOs are used in designs the amount of lost power is negligible as the current being drawn is so small - simply not worth using a switcher for that rail. Also, LDOs typically have cleaner output so often an LDO is used to isolate an analog subsystem from noise on the main (digital) system rails.
Hugo -
+ some designs will have both a switcher and an LDO for the same power rail and switch to the LDO when the current is very low. Switchers get inefficient at low currents, so having both can improve efficiency.
Dan K -
Will you have MacBook Pro 16" 2021(Apple M1 MAX inside) Chip ID?
Hello! We currently don’t have chip ID plans for the M1 Pro Max version.
I’m planning a few projects, can someone provide the logic-board dimensions?
Ahh perfect the CD3217B12 will ultimately fail on these like the CD3217 & CD3215 before them
One of the CD3217B12 in step 5 on the left side is actually a CD3218B12ACE2, most likely the very top one. The CD3218B12ACE2 is responsible for the MagSafe 3 connector.
Does anyone know what is the accelerometer / gyroscope in step 11 doing here? I understand in trackpad Apple need an accelerometer (step 13) to get feedback from the massive “Taptic Engine”, but why on the main board? I recall Thinkpad used to have an accelerometer to stop mechanical hard drive when drastic movement detected. Is it here to stop malfunctioning fans? I’m completely lost here.🤪
MCDP2920 belongs to Kinetic Technologies now after the acquisition of Megachips’ smart connectivity group. (https://www.kinet-ic.com/kinetic-technol...)
luchen_silicon - crwdns2934203:0crwdne2934203:0
Please note that the MegaChips marked MCDP2920 is a Kinetic Technologies product.
Same as for the Apple-TV 2021
Gerard Pasman - crwdns2934203:0crwdne2934203:0
Thanks for the tip! I’ll update the bullet.
Arthur Shi - crwdns2934203:0crwdne2934203:0
what is mTWB for those "Kioxia KICM225UZ0460 128 GB NAND Flash Memory" chips?
Gennadiy Krokodilov - crwdns2934203:0crwdne2934203:0
