Replace the lower case in your MacBook Pro 13" Unibody Mid 2010.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
crwdns2935229:044crwdne2935229:0
Those are actually not seven identical 3 mm screws. The screw located at the ventilation side next to the three 13.5 mm screws does not have a shaft as compared to the other six 3 mm screws.
glaubitz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
