crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Gently pull the display data cable connector away parallel to the board.
Remove the following two screws securing the display data cable bracket to the upper case:
One 8.6 mm Phillips
One 5.6 mm Phillips
Lift the display data cable bracket out of the upper case.
Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
Use your spudger to slide the keyboard ribbon cable out of its socket.
Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
Remove the following screws:
Two 7 mm T6 Torx screws from the DC-In board
Five 3.3 mm T6 Torx screws
Two 4 mm T6 Torx screws
Remove the following Tri-point screws securing the battery to the upper case:
One 5.5 mm Tri-point screw
One 13.5 mm Tri-point screw
Lift the battery out of the upper case.
Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
Pull the logic board away from the side of the upper case and remove it, minding the DC-In board that may get caught.
