crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
Remove the following three screws securing the fan to the upper case:
One 6.5 mm Phillips.
One 5.5 mm Phillips.
One 4.5 mm Phillips.
crwdns2935229:0106crwdne2935229:0
I upgraded my macbook pro 13" mid 2009:
replaced optical drive with 250GB SSD.
replaced 2x2GB RAM with 2x4GB.
replaced old battery..
Things work, except the fan never slows down and makes a lot of noise.
The fan start at full speed as soon as I click the power button, even before the screen lights up.
Please help.
Also the bluetooth and camera stopped working :(
When I reapplied thermal paste to my heat sink ~18 month ago, I had issues reconnecting the camera cable (see Step 10 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement). All of the symptoms you described were exactly those I saw when my camera cable was not properly reconnected. Perhaps you should check here.
If you didn't get a thermal sensor for your ssd your Mac fan will run at full speed 24/7 until you get the sensor
Jake / -
