crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use your fingers to pry the lower case away from the body of the MacBook near the vent.
Remove the lower case.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Carefully pull the camera cable out of its socket on the logic board.
Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
Using the method described in the last step, disconnect the remaining three antenna connectors.
De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
Remove the following five screws:
Two 10.3 mm Phillips screws
Two 3.1 mm Phillips screws
One 5 mm Phillips screw
Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board.
Remove the AirPort/Bluetooth cable.
Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
Remove the AirPort/Bluetooth board from its bracket.
crwdns2935229:094crwdne2935229:0
crwdns2944067:010crwdne2944067:0
If you change your bluetooth card, its MAC address will change. Since pairing is done by MAC, you will need to re-pair all devices.
My Wifi failed, "no hardware found", but the Bluetooth still worked. I replaced the board, but still no dice. Turns out it was the cable. Lesson learned: try the cheaper part first! Not a total loss, now I have Bluetooth 4.
hi there. Where did you get the cable. I'm looking everywhere, but I only see cables with 3 antenna connectors (but I see 4 connectors on the board) & they all have the isight wire (which i need as well).
Also did you find a good tutorial on how to replace the wire rather than the board?
any help here extremely appreciated!
Hello,
I was able to complete this repair in less than 40 minutes, thanks to the author and his easy-to-follow guide!
Regarding Step 10 - I found it easier to use a Phillips #000 screwdriver (instead of the recommended #00 size) for the two “orange” 3.1 mm Phillips screws, as it did not slide off the tiny screw heads like the larger-sized screwdriver would.
This is an amazingly succinct and clear at of instructions! My Hat is of to you!
I discovered that the flat wifi cable was not properly plugged in, so I plugged it back in and went no further! Yea it worked!
