MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the keyboard connector screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the keyboard connector screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.9 mm screws from the keyboard connector bracket.
  2. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard connector bracket.
  3. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the keyboard connector by prying it straight up from the logic board.
  4. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the display board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the display board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  5. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  6. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  7. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Thunderbolt port screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Thunderbolt port screws: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a T3 Torx driver:
    • Remove two 1.4 mm screws from the Thunderbolt port connector bracket on the left.
    • Remove two more 1.4 mm screws from the Thunderbolt port connector bracket on the right.
  8. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left Thunderbolt ports: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left Thunderbolt ports: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left Thunderbolt ports: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the left-side Thunderbolt port connector by prying it straight up from the logic board.
    • Pry from the inside edge, nearest the fan.
    • Gently push the connector aside so it won't interfere with logic board removal.
  9. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right Thunderbolt ports: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right Thunderbolt ports: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right Thunderbolt ports: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside.
  10. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Touch ID connector screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Touch ID connector screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.9 mm screws from the cover bracket securing the Touch ID and 3.5 mm audio jack connectors.
  11. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bracket.
  12. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the headphone jack: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the headphone jack: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the headphone jack: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the 3.5 mm audio jack flex cable by prying it straight up from the logic board.
    • Gently push the flex cable aside.
  13. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect Touch ID: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect Touch ID: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Touch ID and power button flex cable by prying it straight up from the logic board.
  14. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Heat the Touch ID cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Heat the Touch ID cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply mild heat using an iOpener, heat gun, or hair dryer to soften the adhesive under the power button/Touch ID flex cable.
  15. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Pry up the Touch ID cable: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Pry up the Touch ID cable: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Pry up the Touch ID cable: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide an opening pick under the flex cable to separate it from the logic board, and push it carefully aside.
    • Be very careful not to damage this delicate flex cable. The attached Touch ID sensor is uniquely paired to your MacBook's logic board—if damaged, only Apple can successfully replace it.
    • If you have trouble, don't force it—apply a little more heat and try again.
  16. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Touch Bar digitizer screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Touch Bar digitizer screw: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the 1.9 mm screw from the Touch Bar digitizer connector bracket.
  17. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  18. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the Touch Bar digitizer: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the Touch Bar digitizer: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the Touch Bar digitizer by prying its connector straight up from the logic board.
  19. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Touch Bar display screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the Touch Bar display screws: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove two 1.9 mm screws from the Touch Bar display connector bracket.
  20. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  21. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the Touch Bar display: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the Touch Bar display: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the Touch Bar display connector by prying it straight up from the logic board.
  22. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Uncover the microphone connector: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Uncover the microphone connector: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the microphone connector socket.
  23. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the microphone: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the microphone: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
  24. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the microphone cable by pulling it back—away from the fan—until it slides out of its socket.
    • If possible, pull on the attached tape, rather than on the cable itself.
  25. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the connector for the left-side tweeter.
  26. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left tweeter: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left tweeter: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the locking flap for the left-side tweeter ZIF connector by prying it straight up from the logic board.
  27. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable by pulling it towards the tweeter until it slides out of its socket.
    • If possible, pull on the attached tape rather than the cable itself.
  28. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Underneath the tweeter's flex cable lies a second ZIF connector, for the left main speaker.
    • Peel back any tape covering the socket for the left main speaker.
  29. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left main speaker: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the left main speaker: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the locking flap for the left main speaker ZIF connector by prying it straight up from the logic board.
  30. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the left main speaker cable by pulling it toward the tweeter until it slides free from its socket.
    • Remember to pull on the attached tape, not the cable.
  31. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous six steps to disconnect the opposite tweeter and main speaker, on the right.
    • Begin by peeling back any tape covering the tweeter connector.
  32. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right tweeter: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right tweeter: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the locking flap for the right-side tweeter ZIF connector by prying it straight up from the logic board.
  33. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remember to pull on the tape if possible—not the actual cable.
  34. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the connector for the right-side main speaker.
  35. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right main speaker: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the right main speaker: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the locking flap for the right-side main speaker ZIF connector by prying it straight up from the logic board.
  36. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right-side main speaker cable toward the tweeter until it slides free from its socket.
  37. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the antennas: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the antennas: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Disconnect the antennas: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the first antenna cable by prying it straight up from its socket.
    • Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
  38. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the previous step to disconnect the two remaining antenna cables.
    • To reconnect each cable, align the connector directly over its socket, and then press down to snap it into place.
  39. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the antenna bundle screw: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the antenna bundle screw: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the 2.9 mm screw securing the antenna cable bundle.
  40. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Unscrew the logic board: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Unscrew the logic board: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all ten screws securing the logic board assembly:
    • Three 2.5 mm Torx T3 screws
    • Five 2.9 mm Torx T5 screws
    • Two 3.0 mm Torx T5 screws
    • During reassembly, install these screws loosely and adjust the logic board's position if necessary before tightening the screws.
  41. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Peel up the fan dampers: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Peel up the fan dampers: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Peel up the fan dampers: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans.
    • If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
  42. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the logic board assembly: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Remove the logic board assembly: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly.
    • There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
    • Lift from the left side to remove the logic board assembly.
  43. MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Logic board installation: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Logic board installation: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar Late 2016 Logic Board Assembly Replacement, Logic board installation: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When reinstalling the logic board assembly:
    • Check the alignment of the rubber vibration dampers, and adjust them as needed.
    • Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
    • Verify that no cables get trapped under the board as you install it. Check each marked location carefully.
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
443,347 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,995crwdne2935297:0
Microphoneのパーツの説明欄には、Teardownの動画がリンクされていますが、その動画にはMic部分の説明が無いため、このページをリンクしておくと良いと思いました。
This page should be linked In the page of microphone assembly. Threre is not any microphone assembly part in the video embedded in the page.
polo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 357
