MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement
  1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $17.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Battery Connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
  8. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the DC-In board connector straight out of its socket on the logic board.
  9. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • You may need to gently push the display cable out of the way to expose the screws.
  10. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
crwdns2935229:029crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
472.979 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.572crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Thanks very much, took me 10 mins, A nice cheap and fast repair for my damaged MagSafe socket
lewismacqueen - crwdns2934203:0crwdne2934203:0
Thank you for your guidance! Spent $30 on tools as opposed to hundreds and made a simple repair
Brian Smithson - crwdns2934203:0crwdne2934203:0
Thank you ...just what we need !..
Mark White - crwdns2934203:0crwdne2934203:0
Did anyone else lose the display to their MacBook Pro mid 2014 after following this repair?
Vance - crwdns2934203:0crwdne2934203:0
yes I just did and wonder what you did to solve this?
Kaleem -
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 15,968
