Use this guide to replace the right speaker.
This guide is for the speaker on the right side of your notebook when operating normally, during most of the guide it will be on the left, as your laptop will be upside down.
   crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95-
            Remove the following ten screws securing the lower case to the upper case:
            Two 2.3 mm P5 Pentalobe screws
            Eight 3.0 mm P5 Pentalobe screws
            Wedge your fingers between the upper case and the lower case.
            Gently pull the lower case away from the upper case to remove it.
            Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
            Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
            Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
            Lift the logic board end of the I/O board cable straight up to bend it out of the way.
            Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
            Carefully peel the right speaker cable off the upper case.
            Remove the following screws securing the right speaker to the upper case:
            One 5.7 mm T5 Torx screw
            One 6.5 mm T5 Torx screw
            One 3.8 mm T5 Torx screw
            Lift the right speaker from the cable end and pull it free from the case.
crwdns2935229:070crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Easy to follow guide! completed the installation within half an hour. Thanks guys :)
Parfait. Comptez 30 min au total. Merci
I bought all the suggested tools and parts and changed both the left and the right speaker on my wifes Mac Book Pro in 30 minutes. Fantastic guide and site for fixing things. I will come back to this site in the future for DIY repairs. Thank you.
On point, simple and complete, thanks
Waaay too easy — thx!
