MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement
  1. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $16.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Battery Connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Left Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Left Speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
    • Be careful not to damage any surface-mounted components.
  8. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the left speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  9. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
crwdns2935229:087crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
474,907 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023,562crwdne2935297:0
crwdns2947412:017crwdne2947412:0
A very straightforward repair. Thanks for the excellent instructions!
Andrew - crwdns2934203:0crwdne2934203:0
is the same process for the right speaker? thank you very much Sam Lionheart!
Tonino - crwdns2934203:0crwdne2934203:0
Pretty much, there's another cable to disconnect, but we have a whole guide for the right speaker, too! Best of luck!
Sam Goldheart -
Hi! Are the L/R speakers compatible with the 13" Early 2015 models?
fylungster - crwdns2934203:0crwdne2934203:0
Great guide. I was able to dismantle the speaker and fixed the blown left speaker. Fit it back and it worked. Now, i’ll do that for the right speaker.
iamleongch - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 89
crwdns2936753:07crwdne2936753:0 326
crwdns2936753:030crwdne2936753:0 936
crwdns2942667:0crwdne2942667:0 82,174
