Prereq only.
Remove the plastic cover adhered to the battery contact board.
Remove the following screws securing the battery connector board to the logic board:
Two 2.8 mm T6 Torx screws
One 7.0 mm T6 Torx shouldered screw
Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
Carefully lift the battery connector board up off the logic board.
It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
