Use this guide to replace a faulty MagSafe DC-In board.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Pull in the direction of the cable, parallel to the logic board. Do not pull up.
Pull the DC-In board connector straight out of its socket on the logic board.
Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
crwdns2935229:053crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Since a few days the area around the MagSafe-DC is getting quite hot, regardless of wether the Mac is running or idle. Does this have anything to do with the MagSafe-DC? Any recommendations?
Nils Fenske - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Folks,
Just went through these very clear steps on replacing the DC-in board after the pins on my old one were burned.
First off, success…ish with the replacement and the mac is back to charging again in high spirits. However, I am now notified of a “service battery" beneath the charge drop down menu. In checking the system information, the battery is at a cycle count of 824.
I am not quite sure what to do at this point and appreciate any tips.
Best,
random guy on the internet
Joseph Van Linn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Replace the battery.
maccentric - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi there !
My mac won't charge the freshly replaced new battery... event tho it's running fine and recognized by the system...
I've been Changing the battery / Reseting SMC & NVRAM / Clean install on Monterey...
It still tells me :
Power source : power adapter
Battery is not charging
Do you think replacing the DC-in board would help ?
Thanks for your advices !
pulla - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’ve replaced my charging cables and battery. Will be replacing the charging port but if it still doesn’t charge … what might be the problem?
vp3130 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
