This serves as the starting point for every guide—you'll need a P5 Pentalobe screwdriver to remove the lower case and get into the device.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
crwdns2935229:035crwdne2935229:0
crwdns2947412:05crwdne2947412:0
The bottom left-middle screw on my case is jammed and won’t come out—the more I try, the more I’m stripping it. Every other screw has been removed successfully, several times, with no problems. I wonder if I put in the wrong screw from somewhere else? Any ideas for removing it?
Jordan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
do i get a laptop cover for mac book pro retina a 1502 model
naga usha - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
do i get a macbook pro retina A 1502 MODEL laptop cover (hard or soft shell)
I’m trying to install my lower case back but it’s refusing to clip back in. Any way I can fix it?
Jorge Ramirez-Centeno - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
