Use this guide to upgrade or replace the solid-state drive in a MacBook Pro 13” Early 2013. This MacBook Pro uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Pro. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
The lower case is connected to the upper case at the center, with two plastic clips.
Remove the plastic cover adhered to the battery contact board.
The replacement cover doesn't seem to have the formed pads attached. I re-installed the original.
Remove the following screws securing the battery connector board to the logic board:
Two 2.8 mm T6 Torx screws
One 7.0 mm T6 Torx shouldered screw
Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
Is adhered to screw beneath, so lift firmly and slowly.
when doing this with metal tweezers as instructed in the video, it was difficult to get off and apparently while i was trying to do it, the tweezers went too far under and i believe made contact with the screw underneath? there was a zzz noise, an orange flicker and a little stream of smoke that came out. i freaked out and put everything back together to see if the laptop even still worked, it turned on and everything but died right away (i drained it before doing the repair anyway, so i was surprised it turned on at all).
i finished the battery repair and did several other things while in there. i have charged it all the way as recommended and will use it later on to see how everything is, im hoping that it’s a okay, but could someone explain to me what happened and the possible consequences?
Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
When reinstalling, be careful that the board lines up correctly and is completely seated in order for this screw to thread properly.
Carefully lift the battery connector board up off the logic board.
It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
How can I remove interposer I m not able to remove it
you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
I would recommend to use plastic tweezers in order to reduce risk of damage.
Second that. If you have thin heat shrink tubing, form some over the tweezer tips. If the tubing is thin and small enough in diameter you’ll see the serrations of the tweezer tips.
wat is the model this SSD
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
Remove the SSD assembly from the upper case.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the SSD tray.
Insert the edge of plastic opening tool between the SSD and the SSD tray, opposite to the socket side of SSD tray.
Pry the side of the SSD opposite the SSD tray socket out of the SSD tray.
Carefully pull the SSD straight out of its socket on the SSD tray.
SSD remains.
I want to buy external usb casing for this SSD card, could you please tell us if this is mini PCIe mSATA or something else.
A most excellent step by step. I now need to figure out how to grant permission for my backup Air to read my removed Pro SSD files. Perhaps a link from here to that would be helpful.
crwdns2935229:054crwdne2935229:0
crwdns2944067:05crwdne2944067:0
Excelente, muchas gracias
Ok, now that I replaced my SSD - how do I recover my OS?
You can boot your mac to the recovery pressing command + R while you turn on your mac, configure your wifi and then create the partition in the ssd using disk utility, then you can clos disk utility and proceed to the instalation of the OS, the installation will be downloaded from the apple servers so it will depend of your internet speed how long will it take.
Sieht so aus, als würde da eine ganz normale 2,5”-SSD reinpassen, wenn man den Einschub weglässt. Kann man das Kabel am MBP entfernen und ohne den Einschub benutzen?
Familienfreundlicher_Nutzer - crwdns2934203:0crwdne2934203:0
Geht leider nicht. Die neue NVMe m.2 SSD muss eine Übergangslösung haben. Leicht zu finden beim Internett. Das Übergang ist ein kleines Zeug das Mann braucht der Länge und Datei - Brikett zur passen.
If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
Toby Thurston - crwdns2934203:0crwdne2934203:0
Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
timofej.se -
This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
Susan Greer - crwdns2934203:0crwdne2934203:0
It would be a good idea if people recorded in the comments which screws go where so that, if someone lost their screw positions, they could recover them from the comments.
Raymond Shpeley - crwdns2934203:0crwdne2934203:0
