This guide details chip ID information for Apple's MacBook Neo. You can find the full teardown video and analysis here.
Special thanks to our community member Chunglin Chin for contributing to this!
Apple APL1V07 / 339S01851 A18 Pro applications processor layered under a SK hynix H58G66CK8HX139 8 GB LPDDR5X SDRAM memory
Apple APL109A / 343S00866 power management
SanDisk SDMVGKLK8-512G 512 GB NAND flash memory
Likely Apple 338S01330-B0 battery charger
NXP Semiconductors SE310S secure element
Texas Instruments SN2012027 USB Type-C port controller
Winbond W25Q80DV 1 MB serial NOR flash memory
VIA Labs VL122-Q2 4-port USB 2.0 hub
Apple APL109O / 343S00861 power management
Cirrus Logic CS42L83A audio codec
Analog Devices MAX98360B 3.2 W audio amplifier
Texas Instruments TPS630250 adjustable buck-boost converter
Texas Instruments TPS61022 8 A boost converter
Possibly Texas Instruments LM3638 LED backlight driver
Likely GigaDevice serial NOR flash memory
Likely STMicroelectronics serial EEPROM memory
Likely Texas Instruments eUSB2-USB 2.0 dual repeater
DC-DC converter
Texas Instruments INA190A3 current sense amplifier
Texas Instruments TPS259482A 8 A eFuse
Texas Instruments TLV4041R1 single comparator w/ reference
Likely Renesas SLG46108 programmable mixed signal matrix
Likely Renesas mixed signal array
Likely Renesas SLG4xxxx mixed signal array
Texas Instruments TPS7A2018P 300 mA / 1.8 V LDO regulator
Nexperia 74AVC4T245GU 4-bit dual-supply translating transceiver
Texas Instruments SN74AVC4T774 4-bit dual-supply bus transceiver
Texas Instruments LSF0101 single bidirectional multi-voltage level translator
Nexperia 74AXP1T45GX 1-bit dual-supply translating transceiver
Texas Instruments SN74AUP1G17 single Schmitt-trigger buffer
Texas Instruments SN74AUP1G08 single AND gate
Nexperia 74AUP1G08GM single AND gate
Texas Instruments SN74AUP1G34 single buffer
MediaTek MT7932EEA Wi-Fi 6E & Bluetooth 6 controller
Likely Sony CXA4626GC RF switch
Texas Instruments TCAL6416RA I/O expander
Texas Instruments TCAL6416RB I/O expander
Texas Instruments SN74LVC1G32 single OR gate
Texas Instruments SN74AUP1G07 single buffer
Broadcom BCM5976TC1KFB3G touchpad controller
