MacBook Air SSD Replacement
  1. MacBook Air SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case.
    • The two screws on the edge containing the hinge are longer than the others.
    • The eight screws in the corners and remaining edges are shorter.
  2. MacBook Air SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove a single T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Austin Blakely
crwdns2935283:003/11/19crwdne2935283:0
22.186 crwdns2915208:0crwdne2915208:0
crwdns2935297:053crwdne2935297:0
Staff
crwdns2935297:023.401crwdne2935297:0
crwdns2936751:024crwdne2936751:0 167
crwdns2936753:07crwdne2936753:0 1,086
crwdns2936753:030crwdne2936753:0 3,828
crwdns2942667:0crwdne2942667:0 51,657
