MacBook Air 13" Early 2015 Display Assembly Replacement
crwdns2942287:0crwdne2942287:0Prereq for upper case (logic board is removed)
Remove the inner two 5.6 mm T8 Torx screws securing the right display hinge to the upper case.
While holding the Air steady, remove the remaining 5.6 mm T8 Torx screw from the display bracket.
Remove the last 5.6 mm T8 Torx screw securing the display to the upper case.
Open the Air slowly until the hinges slide out of their notches.
Once the two display hinges have cleared the upper case, remove the display and set it aside.
