Use this guide to replace a noisy or nonfunctional fan.
crwdns2935267:0crwdne2935267:0P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
Pull the drive straight out of its socket and remove it from the logic board.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Peel the I/O board cable up from the adhesive securing it to the fan.
Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following three screws securing the fan to the upper case:
Two 5.2 mm T5 Torx screws
One 3.6 mm T5 Torx screw
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
crwdns2935229:025crwdne2935229:0
I think my fan makes some noises when my laptop is cold in the morning... Cold means 18°C... Is it dangerous?
After a few minutes or even seconds, the sound stops.
I’m a 21 y/o college student whose laptop fan was being too loud to use in class and I decided to take matters into my own hands so I took the risk of completing these replacement instructions and I’m so glad I did! My laptop fan no longer makes noise and I didn’t have to take it to Apple and have them overcharge me for something simple enough for me to do at home. Thank you!!
