MacBook Air 11" Early 2015 SSD Replacement
  1. MacBook Air 11" Early 2015 SSD Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    When you say:
    Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
    Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
    Nerdily yours,
    Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
    larryleveen - crwdns2934203:0crwdne2934203:0
    The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
    Michael Welham -
    I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
    Allen - crwdns2934203:0crwdne2934203:0
    The magnetic mat is
    GERARD SZAREK -
    Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
    Frank O'Carroll - crwdns2934203:0crwdne2934203:0
    A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
    Michael Mee - crwdns2934203:0crwdne2934203:0
    Thank you for a really smart tip! I will be using that countless more times!
    Lilljedahl -
    I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
    It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
    I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
    AMG - crwdns2934203:0crwdne2934203:0
    The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
    Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
    Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
    Hope this helps! -Dan
    danielwen -
    I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
    Robert Hermans - crwdns2934203:0crwdne2934203:0
    Hi Robert!
    Try some techniques found in this stripped screw removal guide. Good luck!
    Arthur Shi -
    Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
    vensilver - crwdns2934203:0crwdne2934203:0
    Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
    Arthur Shi -
    The smaller screws went in more easily when I put back all the screws along the hinge edge first.
    Rachel Slatkin - crwdns2934203:0crwdne2934203:0
  2. MacBook Air 11" Early 2015 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    My replacement battery (bought from Fixje in the Netherlands) had a rather thick rubber plate glued onto the top of the battery connector, which made it difficult to reattach the back cover. Specifically, the clip in the middle of the back cover could not reach into the slot.
    The rubber plate could be removed which made the back close (and also made it look like the battery connector of the original battery), but the middle clip would nevertheless not attach with a clicking sound. Still, the back covers attached tightly and does not flex when pressed in the middle.
    It's possible that that specific replacement battery is a hair of a millimetre thicker than the original battery which prevents the middle clip to reach into the slot fully.
    Philip Dygeus - crwdns2934203:0crwdne2934203:0
  3. MacBook Air 11" Early 2015 SSD Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 11" Early 2015 SSD Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
    When reassembling the connector wire needs to be bent to fit.
    GERARD SZAREK - crwdns2934203:0crwdne2934203:0
  4. MacBook Air 11" Early 2015 SSD Replacement, SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Early 2015 SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 11" Early 2015 SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 11" Early 2015 SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the free end of the SSD just enough to get a good hold of it.
    • Do not excessively lift the end of the SSD.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    Which type of SSD used in it…is it PCIe??
    rakesh kumar rout - crwdns2934203:0crwdne2934203:0
    Which type of SSD used in MacBook air 11inch..mid 2013 model???PCIe??
crwdns2935229:060crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
472,860 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,296crwdne2935297:0
crwdns2947412:010crwdne2947412:0
It is possible to upgrade the 128GB ssd to a larger one for this Macbook Air model?
dgoteixeira - crwdns2934203:0crwdne2934203:0
Absolutely. Just click the parts link at the top of the page, and choose your size.
Jeff Suovanen -
I bought the below model SSD by mistake for my Apple 11" Early 2015 model. Could you please suggest whether it will be compatible.
"Samsung 256GB Flash SSD SSUBX/655-1858K w/ Heatsink for Mac Pro 6,1 JPV256R/0A1"
Ramkumar Sundar - crwdns2934203:0crwdne2934203:0
Hi, I am desperately trying to understand how to repair my macbook air 11 inch early 2015. The internal Hd broke. I would like to repair my macbook mounting the SSD suggested by Ifixit but unfortunately the last upgrade of the system was El capitan so, if I understood correctly, I don’t have the right EFI. What can I do? Is there a procedure to install the EFI the SSD owc aura needs? Or should I buy another SSD? Could you suggest me a solution? Thank you in advance for your time
francesca - crwdns2934203:0crwdne2934203:0
You should be able to reinstall or restore everything via macOS recovery. Your Mac should support that:
https://support.apple.com/en-us/HT204904
Just boot up and either reinstall from scratch or follow the instructions to restore from a backup (or the old HD if it still turns on)
Barry K -
These instructions worked very well for me. There were only two issues. First, the battery connector my 13” early 2015 MacBook Air was a simply pull tab; it disconnected easily, coming out of a socket located near the location shown. Second, when I was done, disk utility didn’t see the new SSD. After I opened it up again, disconnected the battery, and reseated the SSD, and reconnected everything, it was fine. I can’t say that the new SSD seats quite as well as the original.
Philip Massey - crwdns2934203:0crwdne2934203:0
Hi, thanks for great looking guide. I’m planning to replace a SSD in MacBook Air early 2015 previously running Yosemite. Thinking of choosing the OWC Aura Pro X2 SSD 240GB.
Have two questions
(1) is there any need of an adapter for the OWC Aura Pro X2 to fit the proprietary storage drive connector of MacBook Air?
(2) If I prior to SSD replacement boot of an external disk and install OSX Mojave, is this sufficient to update the firmware to then find the SSD upon replacement?
Thanks in advance, looking forward to try this out!
Rasmus Malgerud Björgell - crwdns2934203:0crwdne2934203:0
Well, that was flippin’ easy. Probably what took the longest was getting all the tiny screws aligned properly when putting the case back on!
Marc Reeve - crwdns2934203:0crwdne2934203:0
so all i need is a adapter for the ssd a t5 tore screw an pentagone screw and that i it
Juba Sussy - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 107
crwdns2936753:030crwdne2936753:0 381
crwdns2942667:0crwdne2942667:0 71,844
