MacBook Air 11" Early 2015 I/O Board Cable Replacement
  1. MacBook Air 11" Early 2015 I/O Board Cable Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 I/O Board Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 I/O Board Cable Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 11" Early 2015 I/O Board Cable Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 I/O Board Cable Replacement, I/O Board Cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 11" Early 2015 I/O Board Cable Replacement, I/O Board Cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 I/O Board Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the I/O board cable.
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
473 643 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:022 847crwdne2935297:0
Your steps were easy to follow. I didn’t have to replace the I/O board cable just re-connect it. Audio is working once again.
Kim - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 2,625
