Mac mini Mid 2011 Bottom Cover Replacement
  1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
    This took a lot of force on my Mac mini. A lot.
    nh3 - crwdns2934203:0crwdne2934203:0
    I agree. It took a crap ton of force from my thumbs to twist the bottom off.
    sleeve -
    I accidentally broke the little things that hold the cover to the case. Is there a cheap replacement to the cover? Those clips are held onto it very weakly.
    Jacob Halton - crwdns2934203:0crwdne2934203:0
    Don't just use your thumbs... Use your whole palm to twist it, with maybe a thumb in one of the recesses, applying slight downward pressure.
    markbart - crwdns2934203:0crwdne2934203:0
    Wish I would have read this comment before I did it!
    I found that what markbart said works best. one palm one thumb (and my knees) My thumbs would do it. It was a bit at a time.
    Same difficulty getting it back on.
    Would be handy if this (difficulty) was mentioned in the guide
    Also would be nice to mention the safe practice of pressing the power button for a few seconds after disconnected to rid the system of any residual power, working in a clean static free environment & they say on the crucial website to touch a metal surface of the machine before touching the RAM
    Nancy -
    I think it depends, I have seen some that are very difficult to open and some super easy. But I see them everyday. I wish there was a tool that fit in the holes.
    Justin Weathersbee - crwdns2934203:0crwdne2934203:0
    When seating the bottom RAM chip you may have to apply a little extra side force to get it to seat properly. I put in the new RAM and just got a beeping sound upon starting. I then put the old RAM back in and got the same result.
    Here is the solution I found on the Apple discussion board.
    "Take a small flat head screwdriver and after you put the memory in slot 0, put the screwdriver between the top of the mac mini and the memory then turn the screwdriver a little to exert pressure on the memory into the slot. Do it on both sides of the memory."
    This worked for me.
    littlemas2 - crwdns2934203:0crwdne2934203:0
    I remember this when I was changing my memory ... I realized (after opening) that more you push, more force it take to open the cover. As you push down you force the cover "to rub" the casing and possibly other things inside. If you "lightly" hold the cover it comes right off ... Remember: less is more! :-)
    Have fun!
    Radek - crwdns2934203:0crwdne2934203:0
    We found it hard to use the thumbs but if you put the casing on a carpet and one person is holding the case while the other is using his palm of one hand to turn the cover it comes off quite smoothly and without much downward pressure.
    Alexander - crwdns2934203:0crwdne2934203:0
    If you're upgrading to an SSD, before you even take this first step, I'd recommend putting the SSD into an external drive case, using USB and format the SSD first before trying to swap your existing hard drive or implementing a fusion drive. The external drive case will come in handy later so you can use the old drive as extra storage anyhow.
    Once that SSD is internal, the Mac errors out during the formatting process. Once it was formatted externally, then installed inside the Mac again, there was no problem.
    Orange Girl - crwdns2934203:0crwdne2934203:0
    The first time I did this it hurt! The second time my mac mini 2012 had been running so was warm. VERY EASY WHEN WARM. No fun when cool!
    Nancy - crwdns2934203:0crwdne2934203:0
    Forget about those 2 circle indents. if you consider the 2 marked dots (open and close) as position 12 o’clock, place your thumbs at 11 and 1 o’clock on the outer rim of the cover and rotate from that position.
    juicer52 - crwdns2934203:0crwdne2934203:0
    No way was I getting the back off. So I made a tool. Took a large wrench longer than the Mac mini. Superglued 2 rubber feet on the wrench at the same location as the thumb indents. Put the Mac on the ground, between my knees and used my body weight to turn the cover. Worked like a charm.
    Mark - crwdns2934203:0crwdne2934203:0
    Hey dos anyone know if that can lead to the 3 beep RAM problem? I just got a Mac mini witch has the 3 Beeps when started. its not the RAMs them self because thy work in other Macs so if this could lead to thee 3 Beep problem it would make it more Ez because I don't have to Re solder the RAM Port. (This Mac mini was Running over 10 years and after it got turned of for the first Tim it started to have this problem) I think because of Over heading.
    Arvid000 - crwdns2934203:0crwdne2934203:0
  2. Mac mini Mid 2011 Bottom Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
    I have a late 2012 Mac mini, but it must be an earlier version than this late 2012 Mac mini in this description, because removing the hard drive is much more complicated than described here. Please see this YouTube video if you have trouble removing your hard drive with these directions. https://www.youtube.com/watch?v=cvmuQIZP... There is a longer process you've got to go through. It can be done, it just takes much longer. (3-4 hours for me)
    sandyfacebook - crwdns2934203:0crwdne2934203:0
    This applied to me as well. The iFixit article was good and lots of helpful information in the comments but my mini was different and required more dismantling. The video sandyfacebook posted was very helpful in taking me the rest of the way. https://www.youtube.com/watch?v=cvmuQIZP...
    Erik Heerlein -
    My HDD replacement procedure took 2 jours of research, one night sleeping on it and 30 minutes to perform…
    Rene Girardin - crwdns2934203:0crwdne2934203:0
    Step 1: Always wear ESD protection.
    skjell - crwdns2934203:0crwdne2934203:0
crwdns2935229:017crwdne2935229:0
Walter Galan
702,603 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
Jonathan Royce - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 24,754
