Use this guide to replace your mini's heat sink. Reinstalling the heat sink will require a new layer of thermal paste.
            Place your thumbs in the depressions cut into the bottom cover.
            Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
            Tilt the mini enough to allow the bottom cover to fall away from the outer case.
            Remove the bottom cover and set it aside.
            Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
            Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
            Lift the fan out of the mini for enough clearance to access its connector.
            Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
            Remove the fan.
            Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
            Lift the cowling from the end nearest the antenna plate.
            Rotate the cowling away from the outer case and remove it from the mini.
            Remove the following screws securing the antenna plate to the mini:
            Two 6.6 mm T8 or T9 Torx screws
            Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
            Slightly lift the antenna plate from the end closest to the RAM.
            Carefully pull the antenna plate straight away from the circular rim of the outer case.
            Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
            Remove the antenna plate from the mini.
            Remove the following three screws:
            One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
            One 16.2 mm T6 Torx screw
            One 26 mm T6 Torx standoff
            Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
            Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
            To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
            Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
   crwdns2935267:0crwdne2935267:0Mac mini Logic Board Removal Tool$4.99-
            Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
            Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
            Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
            Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
            Use a pair of tweezers to disconnect the power cable from the logic board.
            Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
            Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
            To disconnect the heat sink thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
            Remove the four 8.5 mm T8 Torx screws securing the heat sink to the logic board.
            Remove the heat sink from the logic board, minding any cables that may get caught.
crwdns2935229:09crwdne2935229:0
