Use this guide to easily remove or replace the plastic bottom cover on your Mac mini.
Use an opening tool to pry the bottom cover up off of the Mac mini.
Lift and remove the bottom cover.
Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
Then, press down on the cover to snap its three hidden clips into place.
My antenna plate seems to have TR7 Torx security screws
My Screws were also TR7, 2020 build
Where can i find the cover itself for MM 2018?
Check eBay for unibody Mac mini bottom covers. You can also 3D print one if you want to.
I got as far as this step to do one thing, blow out all the dust. It was far enough and a lot of dust came out. I used a XPower A-2S to blow out the dust.
nirv - crwdns2934203:0crwdne2934203:0
