crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
Remove the single 3.4 mm T6 screw and washer from the antenna cable.
Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
Carefully pull the antenna cable out from the gap between the power supply and case.
Remove the antenna plate from the Mac mini.
Remove the 5 mm T5 screw securing the SSD.
Lift the free end of the SSD up slightly and pull it out of its socket.
Carefully lift the SSD out of the case without scratching or touching the gold contacts.
crwdns2935229:0104crwdne2935229:0
crwdns2944067:029crwdne2944067:0
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Please see my comment later in the thread.
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
Yes, but you need to add a cable to connect it. If you buy the SSD from OWC, they sell a kit which includes the cable and tools (for an extra $20-40, depending on what size/model SSD you get).
shamino -
I have the same question as Juan
