Mac mini Late 2014 Hard Drive Replacement
crwdns2869540:0crwdne2869540:0: 1.1M
119
687
3,003
1,121,600
crwdns2955950:0crwdne2955950:0: 486
crwdns2960004:0254crwdne2960004:0, crwdns2960008:0232crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 1142
crwdns2959974:01142crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 165
crwdns2959982:0165crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0 - crwdns2931291:02crwdne2931291:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Use this guide to replace the hard drive in your hard-drive-only or Fusion Drive Mac mini Late 2014.
This guide was made with a Fusion Drive Mac mini. If your Mac mini only has a hard drive, skip the steps about the PCIe SSD and its connector.
If you're trying to add a SATA drive to a Mac mini that didn't originally have one, you'll need additional components, such as the 821-1501-A. This part is called the "upper cable" and has one of the corners cut off. Don't buy the 821-1500-A part for the 2014 model.
crwdns2959950:0crwdne2959950:0
crwdns2959954:0crwdne2959954:0
    1. Mac mini Late 2014 Hard Drive Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The bottom cover is clipped onto three screw posts.
      • Pry near, but not right on the screw posts.
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
    3. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift and remove the bottom cover.
    1. Mac mini Late 2014 Hard Drive Replacement, Antenna Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following TR6 screws from the antenna plate:
      • Three 4.1 mm screws
      • Three 1.9 mm screws
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
      • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
    3. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
      • Be careful not to lose the washer when removing the screw.
    4. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
    5. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the antenna cable out from the gap between the power supply and case.
    6. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the antenna plate from the Mac mini.
    1. Mac mini Late 2014 Hard Drive Replacement, Fan Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 12 mm T6 screws from the fan.
      • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
      • Do not attempt to remove the fan entirely.
      • Lift the fan straight up to free the captive screw from its hole in the logic board.
      • Pull the fan away from the SSD until you can easily access the fan connector.
    3. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
    4. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the fan from the Mac mini.
    1. Mac mini Late 2014 Hard Drive Replacement, Logic Board Assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the SATA cable connector bracket.
    3. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
    4. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
    5. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
      • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
    6. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the PCIe SSD cable bracket.
    7. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the PCIe SSD connector up off its socket.
    8. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 16 mm T6 screw securing the logic board.
    9. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Mac mini Logic Board Removal Tool
      • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
      • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
    10. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
      • Cease prying when the removal tool makes contact with the opening in the rear case.
      • Remove the Mac mini Logic Board Removal tool.
    11. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the DC-In cable connector straight out of its socket on the logic board.
    12. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
    1. Mac mini Late 2014 Hard Drive Replacement, Power Supply: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement, Power Supply: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement, Power Supply: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The AC-in socket is secured with a small metal retaining clip.
      • Use tweezers or your fingers to pull the clip away from the AC-in socket, and remove it from the Mac mini.
      • When replacing the clip, push it in until it stops—it should be secure even if there is no audible click.
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To free the power supply from the case, grab the AC-In connector, which acts like a latch.
      • Rotate the AC-In connector 90 degrees counter-clockwise.
    3. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The AC-In latch should fit into the groove above it in the case.
      • During reassembly ensure the power supply is inserted far enough into the case that the latch will engage with the groove.
    4. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 8 mm T6 screw securing the power supply.
    5. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the power supply out of the mini, minding any cables that may get caught.
    1. Mac mini Late 2014 Hard Drive Replacement, Drive Tray Assembly: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 8 mm T6 screw securing the drive tray.
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the drive tray up out of the Mac mini.
    1. Mac mini Late 2014 Hard Drive Replacement, Hard Drive Assembly: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement, Hard Drive Assembly: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four (two on each side) 6.5 mm T8 screws securing the hard drive to the drive tray.
    2. Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the hard drive up and remove it from the drive tray.
      • During reassembly, be sure to thread the hard drive cable through the slot in the drive tray.
    1. Mac mini Late 2014 Hard Drive Replacement, Hard Drive: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement, Hard Drive: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 Hard Drive Replacement, Hard Drive: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift up the ribbon cable and carefully peel away the black tape underneath. It secures the SATA cable connector to the PCB of the hard drive. Failing to remove the tape will almost surely cause the contacts soldered to the flex cable to rip from the connector housing, as the retention force of the contacts in the housing is quite low.
      • Pull the SATA cable connector straight out of the hard drive.
      • Carefully peel off the two black, square-shaped sticky pads (one visible in picture) from the corners of the hard drive, and stick them to your new hard drive in the same locations.
crwdns2935229:01142crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
478,746 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,955crwdne2935297:0
crwdns2947412:0232crwdne2947412:0
no problem. but if you can get a evo 850 or a pro for the 2014 is better
Carlos De Bernard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
All in all, this was a fairly terrifying process, however this guide was a massive help! Thankyou!!
geeksix - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is exactly the reason I purchased their tools. They offer these guides which have helped me save several of my computers and a couple of my phones over the years. The $70 was a small price to pay for the help and I love the tools.
Nick Maietta - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Ordered kit which arrived very quickly from Germany to UK. Only problem with taking it apart was with the IR sensor was difficult to lift up and I ended up pulling the whole fitting off glued it back on but now have no working IR sensor or front light but everything else works fine. Swapped SLOW HDD for SSD and now my Mac MIni is flying.
Andrew - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 119
crwdns2936753:07crwdne2936753:0 687
crwdns2936753:030crwdne2936753:0 3,003
crwdns2959996:0crwdne2959996:0 1,121,600
