Mac mini Late 2014 AirPort Card Replacement
  1. Mac mini Late 2014 AirPort Card Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 AirPort Card Replacement, Antenna Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 AirPort Card Replacement, AirPort Card: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  11. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to lift the antenna connectors up off their sockets.
  12. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2.7 mm T5 screw securing the AirPort card.
  13. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the free end of the AirPort card enough to grasp it by the edges.
  14. Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2014 AirPort Card Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini.
crwdns2935229:016crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
474,242 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2935297:023,308crwdne2935297:0
Thanks. Took all of 20 minutes start to finish to upgrade my broken NIC.
Erik Westlund - crwdns2934203:0crwdne2934203:0
Hmm, look like an M.2 interface, could an M.2 SSD be installed instead?
The Bionic Cyclist - crwdns2934203:0crwdne2934203:0
Can confirm that the airport card for the 2015 Macbook Pro fits and functions perfectly as a replacement if you can’t find the mac mini one.
Sam Goddard - crwdns2934203:0crwdne2934203:0
If something wrong with my bluetooth, is it also replace this logic board ?
Gordon Lee - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 113
crwdns2936753:030crwdne2936753:0 357
crwdns2942667:0crwdne2942667:0 22,658
